S.M.A.R.T. results, should I worry?
=== START OF INFORMATION SECTION ===
Device Model: WL400GSA1672
Serial Number: WOL240018242
Firmware Version: 12.06H12
User Capacity: 400,088,457,216 bytes
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 7
ATA Standard is: ATA/ATAPI-7 published, ANSI INCITS 397-2005
Local Time is: Tue Oct 19 22:31:19 2010 EDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0007 232 220 021 Pre-fail Always - 5408
4 Start_Stop_Count 0x0032 099 099 040 Old_age Always - 1611
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 200 200 051 Pre-fail Always - 0
9 Power_On_Hours 0x0032 095 095 000 Old_age Always - 3731
10 Spin_Retry_Count 0x0013 100 100 051 Pre-fail Always - 0
11 Calibration_Retry_Count 0x0013 100 100 051 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 1605
194 Temperature_Celsius 0x0022 116 091 000 Old_age Always - 36
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0012 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0012 200 200 000 Old_age Always - 0
199 UDMA_CRC_Error_Count 0x000a 200 253 000 Old_age Always - 189
200 Multi_Zone_Error_Rate 0x0009 200 200 051 Pre-fail Offline - 0
I was going to download the WD app. just to see what it said for a second opinion, but I can’t find anything for that serial number.
Try what ever diag software you can download and see, most tests are read only. except for the ZERO test.
