See just empty shares whenever I connect to MBL using wd2go or FTP
I really could use help here. I plugged in and installed my new MBL 2TB. Everything seemed fine so I created bunch of shares and began uploading content. Access from anywhere in the network is without any issues.
Only after copying everything I tested Remote access and encountered a problem. I can send the email and register to WD2Go.com without any problems. I log in and see my device. I can see the shares I created. But whenever I open one of them in Explorer, all I can see is an empty folder, no matter how long I wait or how many files there in fact are.
The same issue I have when I use FTP. It was running ok, no problem with logging in but then I sdaw only the folders structure, no content. Today I tried to reboot the MBL and now for some reason I get “Incorrect Password” whenever I try to connect by FTP, although I didn’t change the password and I’m positive I input it properly. Does some of you have any clue what might be going on, please? Just tell me if you need any further info, I’ll be happy to provide.
Thanks!
Ok, empty folders “issue” solved. I didn’t realise that Smartware automatically map only Public Share, not the others, so I accidentally copied all the files somewhere else than I thought.
Malfunctioning FTP problem persists
