Smb.conf max smbd processes = 5, can we please have a little breathing room to a higher number?
Under the main data partition (#24) you have the /data/com.wdc.mycloud.samba/files/smb.conf with the max smbd processes =5. Is it possible to change this to something a little higher and make it stick? What happened is that you don’t necessarily have >5 concurrent clients writing to samba but it would be helpful to have the possibility of more connections without forcibly removing old or preventing new clients and you won’t get the dreaded //MyCloud-012345 … is not accessible errors all the time.
Thank you.
[global]
netbios name = MyCloudDevice
server string = MyCloudDevice
veto files = /:2eDS_Store/.bin/Network Trash Folder/lost+found/mirrored/uploaded/.wdmc/.AppleDouble/
workgroup = WORKGROUP
security = user
printing = bsd
printcap name = /dev/null
disable spoolss = yes
max log size = 0
null passwords = yes
guest account = guest
load printers = no
public = yes
guest ok = yes
passdb backend = smbpasswd:/data/wd/samba/etc/samba/smbpasswd
use sendfile = yes
strict locking = no
min receivefile size = 16384
deadtime = 5
max protocol = SMB3
smb2 leases = yes
fruit:copyfile= yes
log level = 1
debug level = 1
map to guest = bad user
oplocks = yes
kernel oplocks = no
load printers = no
printable = no
enable core files = no
create mask = 0775
force create mode = 0775
directory mask = 0775
force directory mode = 0775
local master = yes
domain master = no
preferred master = auto
os level = 5
dns proxy = no
idmap uid = 10000-65000
idmap gid = 10000-65000
admin users =
#force group = share
unix extensions = no
acl check permissions = false
browseable = yes
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_RCVBUF=2048000 SO_SNDBUF=2048000
smb encrypt = disabled
writeable = yes
delete veto files = yes
veto files = /.nflc_data/.wdmc/.twonky/
[Public]
path = /data/wd/diskVolume0/samba/share
writable = yes
guest ok = yes
Hi @tekram,
Please contact the WD Technical Support team for best assistance and troubleshooting:
https://support-en.wd.com/app/ask
Thank you WDC MCH development team. This appeared to have been corrected with the new FW 8.13.1-102. Example MCH device smb.conf shown below, notice the SMB versions and ntlm auth switch that disabled NTLM v1.
netbios name = MyCloud-0AAAAA
max protocol = SMB3_11
min protocol = SMB2_02
ntlm auth = no
[global]
veto files = /:2eDS_Store/.bin/Network Trash Folder/lost+found/mirrored/uploaded/.AppleDouble/.nflc_data/.wdtmp/.twonky/
security = user
printing = bsd
max log size = 10
guest account = nobody
load printers = no
public = yes
guest ok = yes
passdb backend = smbpasswd:/etc/samba/smbpasswd
use sendfile = yes
strict locking = no
smb2 leases = yes
fruit:copyfile= yes
log level = 1
debug level = 1
oplocks = yes
kernel oplocks = no
aio read size = 0
aio write size = 0
ea support = no
load printers = no
printable = no
create mask = 0775
local master = yes
domain master = no
os level = 5
dns proxy = no
admin users =
browseable = yes
writeable = yes
fruit:aapl = yes
fruit:nfs_aces = no
fruit:veto_appledouble = no
ntlm auth = no
include = /etc/samba/smb-default-share.conf
[mch3]
path = /shares/mch3
public = no
browseable = yes
available = yes
oplocks = yes
follow symlinks = yes
wide links = no
map archive = no
vfs objects = catia fruit streams_xattr
read list =
write list = "mch3"
invalid users =
valid users = "mch3"
root preexec = analyticlog -l INFO -s Samba -m Samba string:state:"connected"
root postexec = analyticlog -l INFO -s Samba -m Samba string:state:"disconnected"
