Stand-by modus
I just bought a WD Mybook live and have a question.
Looks like my WD does not fall into standby mode. If green light stays on, he is inactive and he should be. Over blue Looks like he did not want to fall in standby mode.
Thanks,
Hello Bervo1, if you have recently copied new files to the My Book Live, it will index all of them, this process can take a while depending on the amount of files you transfer. You can also check if any programs or devices are trying to access the My Book. Check page 112 of the manual for more information.
http://www.wdc.com/wdproducts/library/UM/ENG/4779-705058.pdf#page=117
