Hello, I have a WDTV Live Plus and a little problem with the subtitle configuration: I go to Settings->Video Settings-> and turn the “default subtitle value” to Activated, in order to display the subtitles automatically on every movie I watch. But when I turn off the WDTV this setting gets back to “Deactivated” value (and is the only value not remembered of all settings). Anyone with the same problem? I have the lastest firmware. Regards.
Hi there, do you have the same issue when you try older firmware? o.o
The problem persists after the last update (the newer version, automatically updated by the WDTV). But I found that only fails when the “Browser Option” is on “Preview mode” and when I change this value to “List Mode” the subtitle option is now memorized, try it and let me know!.
Regards.
