Subtitles listing but not showing
Hi Everyone,
My first post since picking up the WDTV LIve a couple of months ago.  Overall I’m very happy with it but I’m having trouble understanding why subtitles are not showing.
I see there are lots of threads for this but none seem to fit my issue.
I have ripped my Blu-Rays to MKVs which have the subtitles in them.  I have used mkvmerge to remove the subtitle languages I don’t want.  When I play these with VLC they work fine and I can chose the subtitle language that I want.  When I play these on the WDTV LIve they work fine and pressing options/subtitles brings up the list of subtitle languages.  I select one, then select the Green tick but no subtitles show on the screen.
I have tried this over SMB and DLNA and am using a NAS (ReadyNAS Duo, but this is soon to change to a Synology).
Any help appreciated.  Thought I’d try here first before WD support.
Thanks,
Matt.
How did you rip your blu rays to mkv?
What type of subtitle file is in the mkv?
You could post the complete text output from mediainfo. (Free)
http://mediainfo.sourceforge.net/en
Untick the boxes if you don’t want the extras.
I used AnyDVD to rip them to an ISO and AVS Video Converter to convert to MKV.
Here’s the MediaInfo output (large, I’m afarid).  I see it says the Subtitles are PGS.  Does the WDTV Live not support PGS?
General
Unique ID : 227122734507582008015739629496296388639 (0xAADE3F5F09EC5C9F4E4544447201B81F)
Complete name : Z:\Videos\Movies\Skyfall_t00.mkv
Format : Matroska
Format version : Version 2
File size : 28.5 GiB
Duration : 2h 23mn
Overall bit rate mode : Variable
Overall bit rate : 28.5 Mbps
Movie name : Skyfall
Encoded date : UTC 2013-05-02 15:52:13
Writing application : MakeMKV v1.8.1 win(x64-release)
Writing library : libmakemkv v1.8.1 (1.2.0/1.1.0) win(x64-release)
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 23mn
Bit rate mode : Variable
Bit rate : 23.1 Mbps
Maximum bit rate : 33.2 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.464
Stream size : 23.1 GiB (81%)
Language : English
Default : No
Forced : No
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 2h 23mn
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.51 GiB (5%)
Title : 3/2+1
Language : English
Default : Yes
Forced : No
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 2h 23mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Stream size : 459 MiB (2%)
Title : 3/2+1
Language : English
Default : No
Forced : No
Audio #3
Format : AC-3
Codec ID : A_AC3
Duration : 2h 23mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Title : 3/2+1
Language : Spanish
Default : No
Forced : No
Audio #4
Format : AC-3
Codec ID : A_AC3
Duration : 2h 23mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Title : 3/2+1
Language : French
Default : No
Forced : No
Audio #5
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 2h 23mn
Bit rate : 768 Kbps
Bit depth : 24 bits
Stream size : 786 MiB (3%)
Title : 3/2+1
Language : Italian
Default : No
Forced : No
Audio #6
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 2h 23mn
Bit rate : 768 Kbps
Bit depth : 24 bits
Title : 3/2+1
Language : Russian
Default : No
Forced : No
Audio #7
Format : AC-3
Codec ID : A_AC3
Duration : 2h 23mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Title : 3/2+1
Language : Ukrainian
Default : No
Forced : No
Text #1
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : English
Default : Yes
Forced : No
Text #2
Format : PGS
Language : Spanish
Default : No
Forced : No
Text #3
Format : PGS
Language : Spanish
Default : No
Forced : No
Text #4
Format : PGS
Language : French
Default : No
Forced : No
Text #5
Format : PGS
Language : French
Default : No
Forced : No
Text #6
Format : PGS
Language : Danish
Default : No
Forced : No
Text #7
Format : PGS
Language : Finnish
Default : No
Forced : No
Text #8
Format : PGS
Language : Italian
Default : No
Forced : No
Text #9
Format : PGS
Language : Italian
Default : No
Forced : No
Text #10
Format : PGS
Language : Norwegian
Default : No
Forced : No
Text #11
Format : PGS
Language : Russian
Default : No
Forced : No
Text #12
Format : PGS
Language : Russian
Default : No
Forced : No
Text #13
Format : PGS
Language : Swedish
Default : No
Forced : No
Text #14
Format : PGS
Language : Estonian
Default : No
Forced : No
Text #15
Format : PGS
Language : Icelandic
Default : No
Forced : No
Text #16
Format : PGS
Language : Latvian
Default : No
Forced : No
Text #17
Format : PGS
Language : Lithuanian
Default : No
Forced : No
Text #18
Format : PGS
Language : Chinese
Default : No
Forced : No
Text #19
Format : PGS
Default : No
Forced : No
Text #20
Format : PGS
Default : No
Forced : No
Text #21
Format : PGS
Language : English
Default : No
Forced : No
Text #22
Format : PGS
Language : Danish
Default : No
Forced : No
Text #23
Format : PGS
Language : Finnish
Default : No
Forced : No
Text #24
Format : PGS
Language : Italian
Default : No
Forced : No
Text #25
Format : PGS
Default : No
Forced : No
Text #26
Format : PGS
Language : Russian
Default : No
Forced : No
Text #27
Format : PGS
Language : Swedish
Default : No
Forced : No
Text #28
Format : PGS
Language : Chinese
Default : No
Forced : No
Text #29
Format : PGS
Language : English
Default : No
Forced : No
Text #30
Format : PGS
Language : Danish
Default : No
Forced : No
Text #31
Format : PGS
Language : Finnish
Default : No
Forced : No
Text #32
Format : PGS
Language : Italian
Default : No
Forced : No
Text #33
Format : PGS
Default : No
Forced : No
Text #34
Format : PGS
Language : Russian
Default : No
Forced : No
Text #35
Format : PGS
Language : Swedish
Default : No
Forced : No
Text #36
Format : PGS
Language : Chinese
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:04:28.476 : en:Chapter 02
00:07:32.452 : en:Chapter 03
00:12:47.391 : en:Chapter 04
00:16:47.464 : en:Chapter 05
00:21:37.337 : en:Chapter 06
00:25:00.290 : en:Chapter 07
00:29:25.221 : en:Chapter 08
00:35:06.145 : en:Chapter 09
00:38:27.763 : en:Chapter 10
00:41:24.440 : en:Chapter 11
00:46:22.905 : en:Chapter 12
00:50:48.628 : en:Chapter 13
00:54:53.290 : en:Chapter 14
00:59:38.741 : en:Chapter 15
01:05:14.243 : en:Chapter 16
01:10:16.670 : en:Chapter 17
01:17:09.750 : en:Chapter 18
01:20:55.058 : en:Chapter 19
01:26:10.373 : en:Chapter 20
01:31:49.754 : en:Chapter 21
01:37:04.527 : en:Chapter 22
01:40:49.084 : en:Chapter 23
01:43:45.969 : en:Chapter 24
01:45:54.723 : en:Chapter 25
01:52:10.598 : en:Chapter 26
01:54:45.795 : en:Chapter 27
01:58:13.044 : en:Chapter 28
02:02:49.111 : en:Chapter 29
02:09:38.645 : en:Chapter 30
02:14:49.623 : en:Chapter 31
02:17:46.424 : en:Chapter 32
Thanks!
Do the newbies not bother to read the forum stickies? The WDTV only displays PGS subs that are compressed with zlib as MKVToolnix does by default and MakeMKV does when set to use the WDTV profile.
Thank you Techflaws.  I can’t comment for all newbies but I assure you that this one reads “almost” everything.
