Surprisingly, The WD My Cloud Uses More Power When It Is Shutdown Than When It Sleeps
I’ve only had the My Cloud for about two weeks and I connected it to a Kill-A-Watt to see how much power it used.  Prior to the mistake of updating the firmware from V03.03.01-156 to V03.03.01-165 last night, the My Cloud Sleep function seemed to work ok.  The Kill-A-Watt reported 4 watts when sleeping and 8 watts when “playing” .flac files.  When I was loading the .flac files it used about 10 watts.
Since the sleep function no longer works, last night when I was through using it I shut it down from the Dashboard and it seemed to shut down normally as the front panel light went off after a little while.  Much to my surprise when I looked at the Kill-A-Watt it was reporting 5 watts after the shutdown had completed and was still reading the same this morning - One watt more than when it used to sleep!  Thinking that it might be a problem with the power supply and since the unit was shut down I pulled the power connector out of the back of the My Cloud and the Kill-A-Watt reading went to 0 (zero).  That is really sad when the Shudown state uses more power than the Sleep state.  My Synology DS410 only uses 1 watt when it is sleeping and waiting for a potential Wake-On-LAN request.
Other miscellaneous information:
  1. I am not accessing the Internet, only my local LAN.
  2. Sleep is turned On.
  3. I enabled SSH and FTP but so far have not tried to use it for anything.
  4. Currently I am only using this as the DLNA server for my .flac files to my 2 WD TV SMPs and to share mostly text type files bewteen my main XP system, my W7 notebook, and my 2 Raspberry Pi computers.
  5. I’m using my Retrospect Professional Backup software to back up any critical files on the My Cloud to my XP system.
Hopefully I provided enough information so this sleep and shutdown power issue can be resolved.
That’s normal. Any product will use more power to boot from when you power it off  than when it wakes up from sleep mode.
Hello Nico12345/NETKID,
Is this problem still there?
