I have 2T mbl and at the last week I can’t access to the files.
What can I do? I don’t want to restart and delete al the files.
Thank you.
Itzik
Thank you.
Itzik
Hi nditzik, what color is the My Book Live front light? As a troubleshooting step, you can press the reset button on the back of the My Book for 4 seconds and connect the My Book Ethernet cable directly to the PC.
hello
the color is red and its fleshing.
itzik
hello again,
What to do after connecting my book ethernet cable directly to my pc?
itzik
Hello again, unfortunately if the front LED is Red it means hardware failure. You can check page 12 for the possible causes. I would recommend you to contact tech support directly for further advice on how to recover your data.
http://www.wdc.com/wdproducts/library/UM/ENG/4779-705058.pdf#page=17
