Thumbgen MovieSheets
How can I use Thumbgen MovieSheets on WD TV LIVE HUB.
I build, but I can not see the same moviesheet sheet like thumbgen priview… :((
You need to use a customised theme. The Mochi one will not show them. Find a theme you like and get the movie/tv sheets that work with that theme. Most have templates to download that work with them.
Thanks your support,
Do you have and the offer while you are using a theme and template?
http://community.wdc.com/t5/Themes/List-of-Themes/td-p/122426 :slight_smile:
