Title displayed
Since a few days my Hub has been acting up: it’s has stopped showing titles of movies/TV shows and instead just shows the file name (including .mkv extension). Cleared media library several times, did some reboots, nothing worked. For the movies I found out that by rescanning them one by one I get the titles displayed properly again, however for TV episodes this doesn’t work as I use custom metadata using Tony’s program. As far as I know, TV episode titles normally showed correctly, but now they suddenly won’t… any ways to fix this?
Edit: I’m still on firmware 2.03.24 as I like it the way it is and don’t really care about the added features in the later versions. Could this be the problem?
The only way to confirm if the firmware is the problem is to try another firmware. Either roll back to an older one or update to the new one and see how it goes!
