I have modified the “inc_rv_home_menu_node.xml” file as below;
<?xml version="1.0"?>
<button valkey=“RV_HOME_MENU_MUSIC”
name=" "
normal_bg=“image/main_music_icon_n.png”
focused_bg=“image/main_music_icon_f.png”
disabled_bg=“image/main_music_icon_n.png”/>
<button valkey=“RV_HOME_MENU_SERVICES”
name=" "
normal_bg=“image/main_services_icon_n.png”
focused_bg=“image/main_services_icon_f.png”
disabled_bg=“image/main_services_icon_n.png”/>
<button valkey=“RV_HOME_MENU_VIDEOS”
name=" "
normal_bg=“image/main_videos_icon_n.png”
focused_bg=“image/main_videos_icon_f.png”
disabled_bg=“image/main_videos_icon_n.png”/>
I am using 1280x720 picture size for the “_n” picture file and 1x1for the “_f” picture file.
The problem I have is that sometimes the top two thirds of the screen goes black. This appears to happen randomly (about 50% of the time).
you also need to edit the rv_home.xml (replace the red code with the green code)
<mlmenuview ctrlname=“rv-home-menu” changed=“@@rv-home-menu-changed” style=“rv_home” draw_init_animation=“1” x=“0” y=“458” w=“1280” h=“262” display_item_cnt=“5” dashboard_bar_image=“image/landing_dashboard_top_tab_fake.png”/>
to this
<mlmenuview ctrlname=“rv-home-menu” changed=“@@rv-home-menu-changed” x=“0” y=“0” w=“1280” h=“720” bg=“1” display_item_cnt=“1”/>
Geez mate do you ever sleep? Thanks for the quick reply.
Will change it and let everyone know when it works.
Oops, just realised that I have put this thread in the wrong section - may be I should have put this in the Themes section.
Mods, do you as you wish.
Yes, i just woke up, having a cup of coffee and a slice of toast
P.S. Ive notified a Mod to move this thread to the “Themes” forum
Thanks JoeySmyth for your help.
It worked… but you already knew that didn’t you?
