I’ve read couple threads about the low transfering speed and I need to ask for an advise. My live hub is connected to the router (netgear) by wire. When I start transferring files from my laptop (i tried both wireless and wired connection) the first 10-15 sec it shows speed of about 5-10 Mbs, but within next 30-60 sec it drops donw to 200-300 kbs only. I called WD support and they suggested to exchange the unit and I did. But I have the same issue with another device.
I tried many things (changing ports on the router, changing cables, etc.) - nothing simple helps. But I think the problem is in Live Hub device because I don’t have any issues when I transfer files same way from my laptop to another computer in the network or to Iomega external network harddrive.
Does anybody have an idea of what I might be doing wrong or how to fix the problem? Everybody says 10Mbs is slow - well, I would be happy to have 10Mbs!!! ![]()
Thanks in advance!
