Good day to all!
before write this msg I studied a lot of posts here! tried plenty of differents options to fix this, but untill now no success!
small description of soft & hardware:
Windows 7 Ultimate
PC Dual Core 2 GHz, 4 Gb RAM, Gigabit LAN
TP Link Gigabit Router
WD My Cloud 4 Gb
HP Laptop dv6 with Gigabit LAN
Connected WD My Cloud 4 Gb to rourer and found that trasfer speed via cabels is too slow - max about 100 Mbit/s instead of 1 Gbit/s (even not close to this)
PC connected to router with hi speed cable, CLOUD connected with provided cable. Ligth on back panel both are green, front panel light is steady blue, self check indicate - ok
tried to transfer one large file (2 GB) from PC to Laptop via router all connections wired, good speed - about 600-700 mbit/s per second, with cloud speed is still bad!
tried to connect CLOUD directly to laptop LAN port, front light steady blue and rear lights are both green(indicates 1 Gbit/s speed) BUT NO speed! around 100 Mbit/s
all transfers were made via windows explorer, some test was made via WD software.
tried sollution from this this post - no effect!
SOMEBODY HELP ME! this story is allrady week long for me, can’t eat, can’t sleep =)))) this problem took all my free time, my wife already hate this box! ![]()
