Transmission 1.15 doesn't work after udate to 5.27.157 - WD My cloud WDBCTLxxxxxx-10
I found out that after update transmission into my device it doesn’t work. When i try visit page, I see:
Service Unavailable and when i try to get to transmission link i get:
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
I tried:
Does version 1.16 need to be repackaged for my cloud?
I did not know that. I haven’t installed the update yet. In previous versions, there was no transmission between applications in the single-disk My Cloud. We were installing it ourselves with the bin file.
Could you please tell me, where can I find v1.16 for my device [WDBCTLxxxxxx-10] ? I don’t have app: transmission in my store and I don’t see this app on page: My Cloud OS5 Apps Download Links for manual installation.
This version app MyCloudPR4100_Transmission_1.16.bin and this MyCloudEX2Ultra_Transmission_1.16.bin - doesn’t work with my device, I tried to install.
Transmission is not supported on the OS5 single bay second generation My Cloud.
My Cloud OS 5 & OS 3, The Key Differences in Device Features
https://support-en.wd.com/app/answers/detailweb/a_id/29389
List of Compatible 3rd Party Apps for WD My Cloud OS 5
https://support-en.wd.com/app/answers/detailweb/a_id/29498
Generally only the following apps are supported on the OS5 single bay second generation My Cloud:
GoodSync
Internal Backups
iTunes Server
Remote Backups
Twonky Server
USB Backups
My Cloud OS 5: Download and Install 3rd Party Apps Manually
https://support-en.wd.com/app/answers/detailweb/a_id/29960
Trying to install apps using the WD indicated methods that are not supported may/will likely fail. There may be unofficial methods of getting Transmission onto the OS5 single bay second generation My Cloud. See the search feature to find many past discussions about trying to get Transmission to run/work:
http://wdstagingsplit.staged-by-discourse.com/search?q=transmission%20%23os5%3Amy-cloud-os5
There may be some unsupported apps for OS5 single bay second generation My Cloud’s, like Transmission, at the following link that one may be able to install and get running. These are not supported by WD.
https://wd.hides.su/fox_exe/WDMyCloud-Gen2/Apps/
I disappointed about it. :frowning:
I need to get rid of from this device? Because I have used it only for download torrents.
Thanks for answer and explanation.
Thanks for the explanation. So how I understand if I can’t repackage v1.6 for my device on my own, I need to wait maybe somebody to create an unofficial app transmission or I need to find a new device:(
Hi! Thanks a lot, you’re the best! Where did you find it? I have checked the internet, and couldn’t find. It is working perfectly with my device.
Can you explain to me about repacking, how do you do it? Maybe I’ll do it in the future.
Thank you very much for repacking the app. It will be very helpfull if you create a guide.
