i have a single bay 4TB MyCloud.
I have also a 500GB, a 1TB and a 3TB MyBook.
I connected them to the MyCloud.
Now i wanted to save my data with a backup job.
I recognized that this was aborted after different times.
I have this behaviour with all 3 USB Drives.
I checked all the drives. They seem to be ok.
On ssh with dmesg -w i checked what is happening and found that there seems to be a problem. I would believe in a driver or USB port problem.
Because when i check the dmesg log i can find massages like:
end_request: I/O error, dev sdg, sector 4094646368
But after reset of USB and connecting the drive a:
hdparm --read-sector 4094646368 /dev/sdg works well.
So the I/O error was not produced by the drive.
I am now copying the data by connecting the drive to a PC and copying over network.
But i think the Hardware and Software of the MyCloud should be able to read mass data from USB Drives without resetting the connection randomly.
I tried this with 3 different MyBooks on the USB, with a USB2.0 hub and a USB 3.0 Hub connected and without HUB.
Always the same behavior.
Using the way by connecting the drive on a PC it is working well, but i want to use the backup functionality of the MyCloud drive.
I have bought my MyCloud in the WD Recertified Shop. Is it possible that it is defect?
What can i do to get this problem solved? Any idea?
Here is a dmesg log from the error:
[ 7419.093330] sd 13:0:0:0: [sdg] Invalid command failure
[ 7419.097209] sd 13:0:0:0: [sdg]
[ 7419.099207] Result: hostbyte=0x00 driverbyte=0x08
[ 7419.102644] sd 13:0:0:0: [sdg]
[ 7419.104578] Sense Key : 0x5 [current]
[ 7419.107071] sd 13:0:0:0: [sdg]
[ 7419.109065] ASC=0x24 ASCQ=0x0
[ 7419.110758] sd 13:0:0:0: [sdg] CDB:
[ 7419.113049] cdb[0]=0x28: 28 00 02 2b de fd 00 00 18 00
[ 7419.117147] end_request: critical target error, dev sdg, sector 291436520
[ 7655.578185] usb 3-1.3: reset SuperSpeed USB device number 9 using xhci-hcd
[ 7655.597571] usb 3-1.3: Parent hub missing LPM exit latency info. Power management will be impacted.
[ 7655.605614] xhci-hcd f1058000.usb3: xHCI xhci_drop_endpoint called with disabled ep dd99bc2c
[ 7655.612906] xhci-hcd f1058000.usb3: xHCI xhci_drop_endpoint called with disabled ep dd99bc00
[ 7661.141963] sd 13:0:0:0: [sdg] Invalid command failure
[ 7661.145826] sd 13:0:0:0: [sdg]
[ 7661.147807] Result: hostbyte=0x00 driverbyte=0x08
[ 7661.151228] sd 13:0:0:0: [sdg]
[ 7661.153161] Sense Key : 0x5 [current]
[ 7661.155643] sd 13:0:0:0: [sdg]
[ 7661.157591] ASC=0x24 ASCQ=0x0
[ 7661.159278] sd 13:0:0:0: [sdg] CDB:
[ 7661.161558] cdb[0]=0x28: 28 00 23 c9 1f 71 00 00 18 00
[ 7661.165547] end_request: critical target error, dev sdg, sector 4803066760
[ 7740.500109] hub 3-1:1.0: hub_port_status failed (err = -71)
[ 7740.504628] hub 3-1:1.0: hub_port_status failed (err = -71)
[ 7740.509267] hub 3-1:1.0: hub_port_status failed (err = -71)
[ 7740.513791] hub 3-1:1.0: hub_port_status failed (err = -71)
[ 7740.525990] hub 3-1:1.0: hub_port_status failed (err = -71)
[ 7740.657438] sd 13:0:0:0: [sdg] Unhandled error code
[ 7740.661035] sd 13:0:0:0: [sdg]
[ 7740.662969] Result: hostbyte=0x07 driverbyte=0x00
[ 7740.666386] sd 13:0:0:0: [sdg] CDB:
[ 7740.668700] cdb[0]=0x28: 28 00 1e 81 ea f4 00 00 18 00
[ 7740.672694] end_request: I/O error, dev sdg, sector 4094646176
[ 7740.777397] sd 13:0:0:0: [sdg] Unhandled error code
[ 7740.781011] sd 13:0:0:0: [sdg]
[ 7740.782946] Result: hostbyte=0x07 driverbyte=0x00
[ 7740.786367] sd 13:0:0:0: [sdg] CDB:
[ 7740.788682] cdb[0]=0x28: 28 00 1e 81 eb 0c 00 00 08 00
[ 7740.792676] end_request: I/O error, dev sdg, sector 4094646368
[ 7740.887450] sd 13:0:0:0: [sdg] Unhandled error code
[ 7740.891048] sd 13:0:0:0: [sdg]
[ 7740.892984] Result: hostbyte=0x07 driverbyte=0x00
[ 7740.896401] sd 13:0:0:0: [sdg] CDB:
[ 7740.898725] cdb[0]=0x28: 28 00 1e 81 eb 14 00 00 18 00
[ 7740.902721] end_request: I/O error, dev sdg, sector 4094646432
[ 7741.007426] sd 13:0:0:0: [sdg] Unhandled error code
[ 7741.011024] sd 13:0:0:0: [sdg]
[ 7741.012958] Result: hostbyte=0x07 driverbyte=0x00
[ 7741.016374] sd 13:0:0:0: [sdg] CDB:
[ 7741.018690] cdb[0]=0x28: 28 00 1e 81 eb 2c 00 00 08 00
[ 7741.022686] end_request: I/O error, dev sdg, sector 4094646624
[ 7741.137442] sd 13:0:0:0: [sdg] Unhandled error code
[ 7741.141042] sd 13:0:0:0: [sdg]
[ 7741.142978] Result: hostbyte=0x07 driverbyte=0x00
[ 7741.146399] sd 13:0:0:0: [sdg] CDB:
[ 7741.148724] cdb[0]=0x28: 28 00 1e 81 ea f4 00 00 08 00
[ 7741.152728] end_request: I/O error, dev sdg, sector 4094646176
[ 7741.297418] sd 13:0:0:0: [sdg] Unhandled error code
[ 7741.301018] sd 13:0:0:0: [sdg]
[ 7741.302955] Result: hostbyte=0x07 driverbyte=0x00
[ 7741.306372] sd 13:0:0:0: [sdg] CDB:
[ 7741.308687] cdb[0]=0x28: 28 00 17 48 33 f9 00 00 01 00
[ 7741.312691] end_request: I/O error, dev sdg, sector 3124862920
[ 7741.317284] EXT3-fs (sdg1): warning: dx_probe: Corrupt dir inode 97648641, running e2fsck is recommended.
[ 7741.427397] sd 13:0:0:0: [sdg] Unhandled error code
[ 7741.431038] sd 13:0:0:0: [sdg]
[ 7741.432974] Result: hostbyte=0x07 driverbyte=0x00
[ 7741.436404] sd 13:0:0:0: [sdg] CDB:
[ 7741.438719] cdb[0]=0x28: 28 00 17 48 33 f9 00 00 01 00
[ 7741.442714] end_request: I/O error, dev sdg, sector 3124862920
[ 7741.447299] EXT3-fs error (device sdg1): ext3_find_entry: reading directory #97648641 offset 0
[ 7741.557431] sd 13:0:0:0: [sdg] Unhandled error code
[ 7741.561030] sd 13:0:0:0: [sdg]
[ 7741.562966] Result: hostbyte=0x07 driverbyte=0x00
[ 7741.566383] sd 13:0:0:0: [sdg] CDB:
[ 7741.568704] cdb[0]=0xa: 0a 00 01 00 01 00
[ 7741.571529] end_request: I/O error, dev sdg, sector 2048
[ 7741.575560] Buffer I/O error on device sdg1, logical block 0
[ 7741.579979] lost page write due to I/O error on sdg1
[ 7741.583695] EXT3-fs (sdg1): I/O error while writing superblock
[ 7741.677468] sd 13:0:0:0: [sdg] Unhandled error code
[ 7741.681086] sd 13:0:0:0: [sdg]
[ 7741.683068] Result: hostbyte=0x07 driverbyte=0x00
[ 7741.686550] sd 13:0:0:0: [sdg] CDB:
[ 7741.688917] cdb[0]=0x28: 28 00 17 48 f9 4e 00 00 01 00
[ 7741.692988] end_request: I/O error, dev sdg, sector 3125267056
[ 7741.697771] EXT3-fs error (device sdg1): ext3_find_entry: reading directory #97648641 offset 1
[ 7741.817430] sd 13:0:0:0: [sdg] Unhandled error code
[ 7741.821035] sd 13:0:0:0: [sdg]
[ 7741.822972] Result: hostbyte=0x07 driverbyte=0x00
[ 7741.826390] sd 13:0:0:0: [sdg] CDB:
[ 7741.828697] cdb[0]=0x28: 28 00 17 48 f9 4f 00 00 01 00
[ 7741.937396] sd 13:0:0:0: [sdg] Unhandled error code
[ 7741.940996] sd 13:0:0:0: [sdg]
[ 7741.942933] Result: hostbyte=0x07 driverbyte=0x00
[ 7741.946350] sd 13:0:0:0: [sdg] CDB:
[ 7741.948666] cdb[0]=0x28: 28 00 17 48 f9 50 00 00 06 00
[ 7742.047394] sd 13:0:0:0: [sdg] Unhandled error code
[ 7742.050991] sd 13:0:0:0: [sdg]
[ 7742.052926] Result: hostbyte=0x07 driverbyte=0x00
[ 7742.056344] sd 13:0:0:0: [sdg] CDB:
[ 7742.058663] cdb[0]=0xa: 0a 00 01 00 01 00
[ 7742.061484] Buffer I/O error on device sdg1, logical block 0
[ 7742.065859] lost page write due to I/O error on sdg1
[ 7742.069671] EXT3-fs (sdg1): I/O error while writing superblock
[ 7742.074237] EXT3-fs error (device sdg1): ext3_find_entry: reading directory #97648641 offset 2
[ 7742.177400] sd 13:0:0:0: [sdg] Unhandled error code
[ 7742.180995] sd 13:0:0:0: [sdg]
[ 7742.182929] Result: hostbyte=0x07 driverbyte=0x00
[ 7742.186365] sd 13:0:0:0: [sdg] CDB:
[ 7742.188676] cdb[0]=0xa: 0a 00 01 00 01 00
[ 7742.191495] Buffer I/O error on device sdg1, logical block 0
[ 7742.195871] lost page write due to I/O error on sdg1
[ 7742.199640] EXT3-fs (sdg1): I/O error while writing superblock
[ 7742.204200] EXT3-fs error (device sdg1): ext3_find_entry: reading directory #97648641 offset 3
[ 7742.317416] sd 13:0:0:0: [sdg] Unhandled error code
[ 7742.321016] sd 13:0:0:0: [sdg]
[ 7742.322951] Result: hostbyte=0x07 driverbyte=0x00
[ 7742.326368] sd 13:0:0:0: [sdg] CDB:
[ 7742.328680] cdb[0]=0xa: 0a 00 01 00 01 00
[ 7742.331498] Buffer I/O error on device sdg1, logical block 0
[ 7742.335886] lost page write due to I/O error on sdg1
[ 7742.339635] EXT3-fs (sdg1): I/O error while writing superblock
[ 7742.344214] EXT3-fs error (device sdg1): ext3_find_entry: reading directory #97648641 offset 4
[ 7742.447497] sd 13:0:0:0: [sdg] Unhandled error code
[ 7742.451096] sd 13:0:0:0: [sdg]
[ 7742.453039] Result: hostbyte=0x07 driverbyte=0x00
[ 7742.456483] sd 13:0:0:0: [sdg] CDB:
[ 7742.458817] cdb[0]=0xa: 0a 00 01 00 01 00
[ 7742.461635] Buffer I/O error on device sdg1, logical block 0
[ 7742.466011] lost page write due to I/O error on sdg1
[ 7742.470209] EXT3-fs (sdg1): I/O error while writing superblock
[ 7742.474771] EXT3-fs error (device sdg1): ext3_find_entry: reading directory #97648641 offset 5
[ 7742.577395] sd 13:0:0:0: [sdg] Unhandled error code
[ 7742.580991] sd 13:0:0:0: [sdg]
[ 7742.582925] Result: hostbyte=0x07 driverbyte=0x00
[ 7742.586342] sd 13:0:0:0: [sdg] CDB:
[ 7742.588657] cdb[0]=0xa: 0a 00 01 00 01 00
[ 7742.591478] Buffer I/O error on device sdg1, logical block 0
[ 7742.595852] lost page write due to I/O error on sdg1
[ 7742.599604] EXT3-fs (sdg1): I/O error while writing superblock
[ 7742.604162] EXT3-fs error (device sdg1): ext3_find_entry: reading directory #97648641 offset 6
[ 7742.727449] sd 13:0:0:0: [sdg] Unhandled error code
[ 7742.731063] sd 13:0:0:0: [sdg]
[ 7742.733006] Result: hostbyte=0x07 driverbyte=0x00
[ 7742.736438] sd 13:0:0:0: [sdg] CDB:
[ 7742.738757] cdb[0]=0xa: 0a 00 01 00 01 00
[ 7742.741607] Buffer I/O error on device sdg1, logical block 0
[ 7742.745994] lost page write due to I/O error on sdg1
[ 7742.749879] EXT3-fs (sdg1): I/O error while writing superblock
[ 7742.754439] EXT3-fs error (device sdg1): ext3_find_entry: reading directory #97648641 offset 7
[ 7742.857386] sd 13:0:0:0: [sdg] Unhandled error code
[ 7742.860983] sd 13:0:0:0: [sdg]
[ 7742.862927] Result: hostbyte=0x07 driverbyte=0x00
[ 7742.866344] sd 13:0:0:0: [sdg] CDB:
[ 7742.868655] cdb[0]=0xa: 0a 00 01 00 01 00
[ 7742.871475] Buffer I/O error on device sdg1, logical block 0
[ 7742.875851] lost page write due to I/O error on sdg1
[ 7742.879900] EXT3-fs (sdg1): I/O error while writing superblock
[ 7742.884474] EXT3-fs error (device sdg1): ext3_find_entry: reading directory #97648641 offset 8
[ 7742.987399] sd 13:0:0:0: [sdg] Unhandled error code
[ 7742.990995] sd 13:0:0:0: [sdg]
[ 7742.992929] Result: hostbyte=0x07 driverbyte=0x00
[ 7742.996345] sd 13:0:0:0: [sdg] CDB:
[ 7742.998656] cdb[0]=0xa: 0a 00 01 00 01 00
[ 7743.001476] Buffer I/O error on device sdg1, logical block 0
[ 7743.005850] lost page write due to I/O error on sdg1
[ 7743.009599] EXT3-fs (sdg1): I/O error while writing superblock
[ 7743.077396] sd 13:0:0:0: [sdg] Unhandled error code
[ 7743.080992] sd 13:0:0:0: [sdg]
[ 7743.082926] Result: hostbyte=0x07 driverbyte=0x00
[ 7743.086342] sd 13:0:0:0: [sdg] CDB:
[ 7743.088648] cdb[0]=0x28: 28 00 17 48 f9 56 00 00 01 00
[ 7743.207403] sd 13:0:0:0: [sdg] Unhandled error code
[ 7743.211000] sd 13:0:0:0: [sdg]
[ 7743.212934] Result: hostbyte=0x07 driverbyte=0x00
[ 7743.216360] sd 13:0:0:0: [sdg] CDB:
[ 7743.218674] cdb[0]=0x28: 28 00 17 48 f9 57 00 00 01 00
[ 7743.327385] sd 13:0:0:0: [sdg] Unhandled error code
[ 7743.330996] sd 13:0:0:0: [sdg]
[ 7743.332931] Result: hostbyte=0x07 driverbyte=0x00
[ 7743.336347] sd 13:0:0:0: [sdg] CDB:
[ 7743.338665] cdb[0]=0x28: 28 00 17 48 f9 58 00 00 02 00
[ 7743.492822] sd 13:0:0:0: [sdg] Unhandled error code
[ 7743.496432] sd 13:0:0:0: [sdg]
[ 7743.498408] Result: hostbyte=0x07 driverbyte=0x00
[ 7743.501843] sd 13:0:0:0: [sdg] CDB:
[ 7743.504126] cdb[0]=0x28: 28 00 17 48 f9 59 00 00 01 00
[ 7743.607470] sd 13:0:0:0: [sdg] Unhandled error code
[ 7743.611068] sd 13:0:0:0: [sdg]
[ 7743.613003] Result: hostbyte=0x07 driverbyte=0x00
[ 7743.616420] sd 13:0:0:0: [sdg] CDB:
[ 7743.618736] cdb[0]=0x28: 28 00 17 48 f9 59 00 00 01 00
[ 7743.812477] sd 13:0:0:0: [sdg] Unhandled error code
[ 7743.816101] sd 13:0:0:0: [sdg]
[ 7743.818081] Result: hostbyte=0x07 driverbyte=0x00
[ 7743.821503] sd 13:0:0:0: [sdg] CDB:
[ 7743.823784] cdb[0]=0x28: 28 00 17 48 f9 59 00 00 01 00
[ 7743.987416] sd 13:0:0:0: [sdg] Unhandled error code
[ 7743.991014] sd 13:0:0:0: [sdg]
[ 7743.992950] Result: hostbyte=0x07 driverbyte=0x00
[ 7743.996368] sd 13:0:0:0: [sdg] CDB:
[ 7743.998685] cdb[0]=0x28: 28 00 17 48 f9 59 00 00 01 00
[ 7744.002785] EXT3-fs error (device sdg1): ext3_find_entry: reading directory #97648641 offset 9
[ 7744.107479] sd 13:0:0:0: [sdg] Unhandled error code
[ 7744.111077] sd 13:0:0:0: [sdg]
[ 7744.113011] Result: hostbyte=0x07 driverbyte=0x00
[ 7744.116429] sd 13:0:0:0: [sdg] CDB:
[ 7744.118744] cdb[0]=0xa: 0a 00 01 00 01 00
[ 7744.121562] Buffer I/O error on device sdg1, logical block 0
[ 7744.125938] lost page write due to I/O error on sdg1
[ 7744.130028] EXT3-fs (sdg1): I/O error while writing superblock
[ 7744.134637] EXT3-fs error (device sdg1): ext3_find_entry: reading directory #97648641 offset 10
[ 7744.237388] sd 13:0:0:0: [sdg] Unhandled error code
[ 7744.241000] sd 13:0:0:0: [sdg]
[ 7744.242935] Result: hostbyte=0x07 driverbyte=0x00
[ 7744.246351] sd 13:0:0:0: [sdg] CDB:
[ 7744.248663] cdb[0]=0xa: 0a 00 01 00 01 00
[ 7744.251509] EXT3-fs (sdg1): I/O error while writing superblock
[ 7744.256072] EXT3-fs error (device sdg1): ext3_find_entry: reading directory #97648641 offset 11
[ 7744.367383] sd 13:0:0:0: [sdg] Unhandled error code
[ 7744.370999] sd 13:0:0:0: [sdg]
[ 7744.372956] Result: hostbyte=0x07 driverbyte=0x00
[ 7744.376388] sd 13:0:0:0: [sdg] CDB:
[ 7744.378716] cdb[0]=0xa: 0a 00 01 00 01 00
[ 7744.381563] EXT3-fs (sdg1): I/O error while writing superblock
[ 7744.487455] sd 13:0:0:0: [sdg] Unhandled error code
[ 7744.491057] sd 13:0:0:0: [sdg]
[ 7744.493011] Result: hostbyte=0x07 driverbyte=0x00
[ 7744.496443] sd 13:0:0:0: [sdg] CDB:
[ 7744.498761] cdb[0]=0x28: 28 00 17 48 f9 59 00 00 01 00
[ 7744.617413] sd 13:0:0:0: [sdg] Unhandled error code
[ 7744.621010] sd 13:0:0:0: [sdg]
[ 7744.622944] Result: hostbyte=0x07 driverbyte=0x00
[ 7744.626362] sd 13:0:0:0: [sdg] CDB:
[ 7744.628675] cdb[0]=0x28: 28 00 17 48 f9 59 00 00 01 00
[ 7744.737241] sd 13:0:0:0: [sdg] Unhandled error code
[ 7744.740901] sd 13:0:0:0: [sdg]
[ 7744.742849] Result: hostbyte=0x07 driverbyte=0x00
[ 7744.746266] sd 13:0:0:0: [sdg] CDB:
[ 7744.748565] cdb[0]=0x28: 28 00 17 48 f9 59 00 00 01 00
[ 7744.867441] sd 13:0:0:0: [sdg] Unhandled error code
[ 7744.871039] sd 13:0:0:0: [sdg]
[ 7744.872995] Result: hostbyte=0x07 driverbyte=0x00
[ 7744.876433] sd 13:0:0:0: [sdg] CDB:
[ 7744.878833] cdb[0]=0x28: 28 00 17 48 f9 59 00 00 01 00
[ 7745.013883] sd 13:0:0:0: [sdg] Unhandled error code
[ 7745.017530] sd 13:0:0:0: [sdg]
[ 7745.019469] Result: hostbyte=0x07 driverbyte=0x00
[ 7745.022886] sd 13:0:0:0: [sdg] CDB:
[ 7745.025166] cdb[0]=0x28: 28 00 17 48 f9 59 00 00 01 00
[ 7745.127473] sd 13:0:0:0: [sdg] Unhandled error code
[ 7745.131080] sd 13:0:0:0: [sdg]
[ 7745.133016] Result: hostbyte=0x07 driverbyte=0x00
[ 7745.136434] sd 13:0:0:0: [sdg] CDB:
[ 7745.138743] cdb[0]=0x2a: 2a 00 1a a8 01 32 00 00 01 00
[ 7745.237473] sd 13:0:0:0: [sdg] Unhandled error code
[ 7745.241118] sd 13:0:0:0: [sdg]
[ 7745.243056] Result: hostbyte=0x07 driverbyte=0x00
[ 7745.246493] sd 13:0:0:0: [sdg] CDB:
[ 7745.248820] cdb[0]=0x28: 28 00 17 48 f9 59 00 00 01 00
[ 7745.261576] usb 1-1: USB disconnect, device number 13
[ 7745.265411] usb 1-1.1: USB disconnect, device number 14
[ 7745.347504] sd 13:0:0:0: [sdg] Unhandled error code
[ 7745.351119] sd 13:0:0:0: [sdg]
[ 7745.353069] Result: hostbyte=0x07 driverbyte=0x00
[ 7745.356498] sd 13:0:0:0: [sdg] CDB:
[ 7745.358833] cdb[0]=0x28: 28 00 17 48 f9 59 00 00 01 00
[ 7745.362787] usb 1-1.2: USB disconnect, device number 15
[ 7745.472612] sd 13:0:0:0: [sdg] Unhandled error code
[ 7745.476281] sd 13:0:0:0: [sdg]
[ 7745.478332] Result: hostbyte=0x07 driverbyte=0x00
[ 7745.481850] sd 13:0:0:0: [sdg] CDB:
[ 7745.483576] hotPlug.sh begin(seq=945)…
[ 7745.486782] cdb[0]=0x2a: 2a 00 1a a8 01 34 00 00 01 00
[ 7745.587551] sd 13:0:0:0: [sdg] Unhandled error code
[ 7745.591167] sd 13:0:0:0: [sdg]
[ 7745.593115] Result: hostbyte=0x07 driverbyte=0x00
[ 7745.594855] hotPlug.sh end(seq=945).
[ 7745.598895] sd 13:0:0:0: [sdg] CDB:
[ 7745.601192] cdb[0]=0x28: 28 00 17 48 f9 59 00 00 01 00
[ 7745.687428] usb 1-1: new high-speed USB device number 17 using orion-ehci
[ 7745.697610] sd 13:0:0:0: [sdg] Unhandled error code
[ 7745.701210] sd 13:0:0:0: [sdg]
[ 7745.703144] Result: hostbyte=0x07 driverbyte=0x00
[ 7745.706562] sd 13:0:0:0: [sdg] CDB:
[ 7745.708887] cdb[0]=0x28: 28 00 17 48 f9 59 00 00 01 00
[ 7745.712883] blk_update_request: 30 callbacks suppressed
[ 7745.716824] end_request: I/O error, dev sdg, sector 3125267144
[ 7745.817444] sd 13:0:0:0: [sdg] Unhandled error code
[ 7745.821041] sd 13:0:0:0: [sdg]
[ 7745.822986] Result: hostbyte=0x07 driverbyte=0x00
[ 7745.826411] sd 13:0:0:0: [sdg] CDB:
[ 7745.828723] cdb[0]=0x28: 28 00 17 48 f9 59 00 00 01 00
[ 7745.832717] end_request: I/O error, dev sdg, sector 3125267144
[ 7745.846201] hub 1-1:1.0: USB hub found
[ 7745.849374] hub 1-1:1.0: 4 ports detected
[ 7745.957676] sd 13:0:0:0: [sdg] Unhandled error code
[ 7745.961297] sd 13:0:0:0: [sdg]
[ 7745.963266] Result: hostbyte=0x07 driverbyte=0x00
[ 7745.966692] sd 13:0:0:0: [sdg] CDB:
[ 7745.969015] cdb[0]=0x28: 28 00 17 48 f9 59 00 00 01 00
[ 7745.973009] end_request: I/O error, dev sdg, sector 3125267144
[ 7746.077515] sd 13:0:0:0: [sdg] Unhandled error code
[ 7746.081129] sd 13:0:0:0: [sdg]
[ 7746.083075] Result: hostbyte=0x07 driverbyte=0x00
[ 7746.086498] sd 13:0:0:0: [sdg] CDB:
[ 7746.088845] cdb[0]=0x28: 28 00 17 48 f9 59 00 00 01 00
[ 7746.092853] end_request: I/O error, dev sdg, sector 3125267144
[ 7746.145631] hotPlug.sh begin(seq=957)…
[ 7746.207498] sd 13:0:0:0: [sdg] Unhandled error code
[ 7746.211096] sd 13:0:0:0: [sdg]
[ 7746.213032] Result: hostbyte=0x07 driverbyte=0x00
[ 7746.216449] sd 13:0:0:0: [sdg] CDB:
[ 7746.218763] cdb[0]=0x28: 28 00 17 48 f9 59 00 00 01 00
[ 7746.222824] end_request: I/O error, dev sdg, sector 3125267144
[ 7746.237464] usb 3-1: USB disconnect, device number 8
[ 7746.241153] usb 3-1.3: USB disconnect, device number 9
[ 7746.247649] sd 13:0:0:0: [sdg] Unhandled error code
[ 7746.251304] sd 13:0:0:0: [sdg]
[ 7746.253253] Result: hostbyte=0x01 driverbyte=0x00
[ 7746.256703] sd 13:0:0:0: [sdg] CDB:
[ 7746.259070] cdb[0]=0x28: 28 00 17 48 f9 59 00 00 01 00
[ 7746.263151] end_request: I/O error, dev sdg, sector 3125267144
[ 7746.326843] hotPlug.sh end(seq=957).
[ 7746.667586] usb 3-1: new SuperSpeed USB device number 10 using xhci-hcd
[ 7746.689335] usb 3-1: Parent hub missing LPM exit latency info. Power management will be impacted.
[ 7746.733608] hub 3-1:1.0: USB hub found
[ 7746.736466] hub 3-1:1.0: 4 ports detected
[ 7746.828404] usb 1-1.1: new high-speed USB device number 18 using orion-ehci
[ 7746.967827] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[ 7746.991835] scsi14 : usb-storage 1-1.1:1.0
[ 7747.088110] usb 1-1.2: new high-speed USB device number 19 using orion-ehci
[ 7747.230887] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[ 7747.316767] scsi15 : usb-storage 1-1.2:1.0
[ 7747.408327] usb 1-1.3: new high-speed USB device number 20 using orion-ehci
[ 7747.502618] EXT4-fs error (device sde1): ext4_find_entry:1309: inode #2: comm smbcom: reading directory lblock 0
[ 7747.517751] EXT4-fs error (device sde1): ext4_find_entry:1309: inode #2: comm smbcom: reading directory lblock 0
[ 7747.543070] EXT4-fs error (device sde1): ext4_find_entry:1309: inode #2: comm smbcom: reading directory lblock 0
[ 7747.679539] EXT4-fs error (device sdf1): ext4_find_entry:1309: inode #2: comm smbcom: reading directory lblock 0
[ 7747.692656] EXT4-fs error (device sdf1): ext4_find_entry:1309: inode #2: comm smbcom: reading directory lblock 0
[ 7747.704984] EXT4-fs error (device sdf1): ext4_find_entry:1309: inode #2: comm smbcom: reading directory lblock 0
[ 7747.737640] EXT3-fs error (device sdg1): ext3_find_entry: reading directory #2 offset 0
[ 7747.754956] ------------[ cut here ]------------
[ 7747.758352] WARNING: at fs/fs-writeback.c:1196 __mark_inode_dirty+0xfc/0x1f4()
[ 7747.764300] bdi-block not registered
[ 7747.766580] Modules linked in: netatop(O) tun ufsd(PO) jnl(O)
[ 7747.771174] CPU: 1 PID: 28346 Comm: smbcom Tainted: P W O 3.10.39 #1
[ 7747.776981] [] (unwind_backtrace+0x0/0xe4) from [] (show_stack+0x10/0x18)
[ 7747.784273] [] (show_stack+0x10/0x18) from [] (warn_slowpath_common+0x4c/0x68)
[ 7747.792018] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c)
[ 7747.800349] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (__mark_inode_dirty+0xfc/0x1f4)
[ 7747.808617] [] (__mark_inode_dirty+0xfc/0x1f4) from [] (ext3_commit_super.constprop.19+0x84/0xdc)
[ 7747.818023] [] (ext3_commit_super.constprop.19+0x84/0xdc) from [] (ext3_handle_error+0x98/0xc8)
[ 7747.827205] [] (ext3_handle_error+0x98/0xc8) from [] (ext3_error+0x40/0x50)
[ 7747.834691] [] (ext3_error+0x40/0x50) from [] (ext3_find_entry+0x3cc/0x594)
[ 7747.842143] [] (ext3_find_entry+0x3cc/0x594) from [] (ext3_lookup+0x28/0xd0)
[ 7747.849702] [] (ext3_lookup+0x28/0xd0) from [] (lookup_real+0x30/0x50)
[ 7747.856729] [] (lookup_real+0x30/0x50) from [] (__lookup_hash+0x30/0x40)
[ 7747.863971] [] (__lookup_hash+0x30/0x40) from [] (lookup_slow+0x3c/0xa0)
[ 7747.871163] [] (lookup_slow+0x3c/0xa0) from [] (path_lookupat+0xf8/0x764)
[ 7747.878436] [] (path_lookupat+0xf8/0x764) from [] (filename_lookup+0x20/0x64)
[ 7747.886046] [] (filename_lookup+0x20/0x64) from [] (user_path_at_empty+0x54/0x80)
[ 7747.894013] [] (user_path_at_empty+0x54/0x80) from [] (user_path_at+0x10/0x18)
[ 7747.901722] [] (user_path_at+0x10/0x18) from [] (SyS_faccessat+0xac/0x1bc)
[ 7747.909112] [] (SyS_faccessat+0xac/0x1bc) from [] (ret_fast_syscall+0x0/0x30)
[ 7747.916728] —[ end trace 21fa25aa2bb503e3 ]—
[ 7747.920098] quiet_error: 4 callbacks suppressed
[ 7747.923343] Buffer I/O error on device sdg1, logical block 0
[ 7747.927717] lost page write due to I/O error on sdg1
[ 7747.931415] EXT3-fs (sdg1): I/O error while writing superblock
[ 7747.959009] EXT3-fs error (device sdg1): ext3_find_entry: reading directory #2 offset 0
[ 7747.985201] Buffer I/O error on device sdg1, logical block 0
[ 7747.989583] lost page write due to I/O error on sdg1
[ 7747.993333] EXT3-fs (sdg1): I/O error while writing superblock
[ 7747.997796] usb 3-1.3: new SuperSpeed USB device number 11 using xhci-hcd
[ 7748.014608] EXT3-fs error (device sdg1): ext3_find_entry: reading directory #2 offset 0
[ 7748.018619] usb 3-1.3: Parent hub missing LPM exit latency info. Power management will be impacted.
[ 7748.031509] usb-storage 3-1.3:1.0: USB Mass Storage device detected
[ 7748.043558] scsi 14:0:0:0: Direct-Access WD 5000AAKB Externa l108 PQ: 0 ANSI: 0
[ 7748.049023] Buffer I/O error on device sdg1, logical block 0
[ 7748.049027] lost page write due to I/O error on sdg1
[ 7748.049036] EXT3-fs (sdg1): I/O error while writing superblock
[ 7748.051037] scsi16 : usb-storage 3-1.3:1.0
[ 7748.113690] sd 14:0:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 7748.122215] sd 14:0:0:0: [sdb] Write Protect is off
[ 7748.125841] sd 14:0:0:0: [sdb] Mode Sense: 03 00 00 00
[ 7748.134092] sd 14:0:0:0: [sdb] No Caching mode page found
[ 7748.138326] sd 14:0:0:0: [sdb] Assuming drive cache: write through
[ 7748.143376] sd 14:0:0:0: Attached scsi generic sg1 type 0
[ 7748.166049] sd 14:0:0:0: [sdb] No Caching mode page found
[ 7748.170285] sd 14:0:0:0: [sdb] Assuming drive cache: write through
[ 7748.337773] scsi 15:0:0:0: Direct-Access WD 10EAVS External 1.65 PQ: 0 ANSI: 4
[ 7748.454142] hotPlug.sh begin(seq=973)…
[ 7748.549038] sd 15:0:0:0: [sdc] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
[ 7748.559376] sd 15:0:0:0: [sdc] Write Protect is off
[ 7748.563172] sd 15:0:0:0: [sdc] Mode Sense: 21 00 00 00
[ 7748.576652] sd 15:0:0:0: [sdc] No Caching mode page found
[ 7748.580906] sd 15:0:0:0: [sdc] Assuming drive cache: write through
[ 7748.587926] sd 15:0:0:0: Attached scsi generic sg2 type 0
[ 7748.601022] sd 15:0:0:0: [sdc] No Caching mode page found
[ 7748.605177] sd 15:0:0:0: [sdc] Assuming drive cache: write through
[ 7748.865255] EXT4-fs error (device sde1): ext4_read_inode_bitmap:175: comm smbcom: Cannot read inode bitmap - block_group = 0, inode_bitmap = 1041
[ 7748.892501] EXT4-fs error (device sde1): ext4_read_inode_bitmap:175: comm smbcom: Cannot read inode bitmap - block_group = 0, inode_bitmap = 1041
[ 7748.988414] EXT4-fs error (device sdf1): ext4_read_inode_bitmap:175: comm smbcom: Cannot read inode bitmap - block_group = 0, inode_bitmap = 1041
[ 7749.003914] EXT4-fs error (device sdf1): ext4_read_inode_bitmap:175: comm smbcom: Cannot read inode bitmap - block_group = 0, inode_bitmap = 1041
[ 7749.047058] hotPlug.sh end(seq=973).
[ 7749.061718] scsi 16:0:0:0: Direct-Access WD My Book 1130 1012 PQ: 0 ANSI: 6
[ 7749.107608] sd 16:0:0:0: [sdd] 732558336 4096-byte logical blocks: (3.00 TB/2.72 TiB)
[ 7749.117973] sd 16:0:0:0: [sdd] Write Protect is off
[ 7749.121615] sd 16:0:0:0: [sdd] Mode Sense: 47 00 10 08
[ 7749.151793] sd 16:0:0:0: Attached scsi generic sg3 type 0
[ 7749.165820] sd 16:0:0:0: [sdd] No Caching mode page found
[ 7749.170022] sd 16:0:0:0: [sdd] Assuming drive cache: write through
[ 7749.176036] scsi 16:0:0:1: Enclosure WD SES Device 1012 PQ: 0 ANSI: 6
[ 7749.191600] EXT3-fs error (device sdg1): read_inode_bitmap: Cannot read inode bitmap - block_group = 8193, inode_bitmap = 268476930
[ 7749.206911] sd 16:0:0:0: [sdd] 732558336 4096-byte logical blocks: (3.00 TB/2.72 TiB)
[ 7749.230342] sd 16:0:0:0: [sdd] No Caching mode page found
[ 7749.231891] Buffer I/O error on device sdg1, logical block 0
[ 7749.231895] lost page write due to I/O error on sdg1
[ 7749.231904] EXT3-fs (sdg1): I/O error while writing superblock
[ 7749.231909] EXT3-fs (sdg1): error in ext3_new_inode: IO failure
[ 7749.235955] Buffer I/O error on device sdg1, logical block 0
[ 7749.235958] lost page write due to I/O error on sdg1
[ 7749.235964] EXT3-fs (sdg1): I/O error while writing superblock
Thanks,
Stefan
