Guys, I need you help PLEASE. I have been wrecking my brain for the past couple of days, re-installing WHS 2011, FlexRAID, even formatted my hard drives on the server and checked them. Everything is fine on the server end.
- My issue is that my WDTV LIVE SMP, for some reason, starts buffering very often on 1080p mkv movies. I get that circular arrow in the middle of the screen for a few seconds, the movie pauses but then resumes after about 4-5 seconds.
The hard drives are fine and the server is connected to the network at 1Gbps. Everything is connected through the router.
- Usually when this happens and I get to the end of a show or movie I have a pop-up that comes up as “There is no medial content in the selected folder” or something along those lines. And I have to go into the change source option at the top -->Windows Shares–>WHS, etc…
Also, the only time my shows and movies are in aphabetical order is when I select the share, via the windows shares method on the local network.
If I filter by “My Medica Library” than the show episodes, and movie names are all out of order…
I would really appreiate some help guys as it makes movie watching absolutely un-acceptable since it occasionally pauses and buffers. And sometimes all of a sudden says on media is found in the folder.
Any idea why this is happening and how I could fix it? Would really appreciate it guys.
