Verify firmware
Just got my new myCloud – really excited.
Was following the setup on my macbook pro when i hit this road block:
Any ideas what to do??
Go to the Dashboard (in browser, go to url:  http://wdmycloud.com/ ) and report back what firmware version it is on.  it will be displayed on the Dashboard in the “Firmware” box.
My dashboard wont display either.
I have tried safari and google chrome, but get stuck on “attempting to authenticate”
any thoughts?
Can you see the mycloud on your network.
My router is bust so I am running it directly attached to my macbook pro.
To answer your question yes it appears in my finder as a netwrok attached drive.
Put simply I cannot configure it as I cannot get by the above screenshot nor the “attempting to authenticate” in the browser.
And yes I am using ethernet connection not the USB 3.0
Running it directly connected is probably causing the problem.
