OK everyone, here’s what I’ve got.
I’m trying to go with a wireless setup but am getting stuttering problems when playing back video, especially on DVD ISO files. What’s happening is that the video is stuttering really bad and eventually gets to the ponit where it just won’t play at all. Netflix and compressed videos (m4v) also stutter but not always as bad. I would call this somewhat intermittent, as at times its worse than others.
I have a Linksys WRT54G running DD-WRT and all my devices connect to it just fine. On the WD end, I’ve tried 2 different wireless connection options. First I tried the Airlink AWL5077 card that I’ve seen recommended on here and it connected just fine, but when launching a video it had the stuttering problem. Thinking maybe that adapter wasn’t strong enough of the box just didn’t like wireless for some reason, I bought one of those Netgear Universal wireless adapters. This should have addressed each of the potential issues, as the connection strength from that device to my router was excellent, and as far as the WD box knows it’s using a wired connection so it wouldn’t be triggering any kind of built in issue with the box in regards to wireless video streaming. I had identical results with the Netgear device though, stuttering.
Well, that leaves the potential culprit as my router. Its a great router, and I thought 54G would be plenty fast for streaming video, but am wondering if there’s something unique about the WD box that it requires more bandwidth. The reason I say that is that I’ve got 2 TiVo boxes (one right next to the WD and one in a room even further away from the router) that stream Netflix and video just fine. I also have an Apple TV in the far room that streams Netflix and video just fine. Granted I can’t test the same iso files on either of those devices because neither support it (which is why I bought the WD box to begin with).
So, that leaves the WD box. Maybe it can’t handle these big iso files very well? Well I hookedit up a hard wired connection and it worked beautifully, watched 2 hours of a movie last night with not one problem. So the box can handle it. Again the Netgear device would have addressed anything along the lines of the WD box ‘thinking’ that it had to adjust something because of a wireless connection because the box sees that as a wired connection.
OK, so maybe wireless G just isn’t fast enough to support streaming files this big quick enough. Well that can’t be right, by my calculations the iso files should require absolutely no more than 2 MB streaming capability, and actually much less than that in reality, and I know my router is working quicker than that.
SO, I’m kinda lost as to what to try next. I could try a new router, but have no actual logical reasoning to do that, so I’m looking for any help here.
Thanks for your time.
