WARNING - MyCloud OS5
This is to warn anyone wants to upgrade your MyCloud device from OS3 to OS5, the missing main function of OS5 is you won’t be able to download the entire Folder anymore. Imagine you are somewhere outside and need to install the pre-purchased software save in your MyCloud device at home. You can’t download the whole folder no more. Haven’t gone through entirely whether other type of file will have similar issue with this.
But this is the big downside of OS5 and if you are ok with OS3 which is worked fine previously, don’t upgrade the firmware.
@danai You have posted your topic in the My Cloud Home sub-forum. OS5 does not work on this device. Check out devices for OS5 here http://wdstagingsplit.staged-by-discourse.com/t/what-is-the-my-cloud-os-5-limited-public-release/256492
You should post your topic on the WD Community. Look for this.
