I went ahead and purchased a wd caviar black from Amazon.com while I reside in Canada. When I got the drive I proceeded to wd website to check the warranty and it comes up as out of region. Now my concern is if something happens to the drive am I out of luck because I live in Canada and it won’t be covered for warranty?
Welcome to the Community.
WD Support is able to change your hard drive’s region if needed since WD offers world-wide RMA services.
How would I go about getting them to change the region? Do I just contact them?
That is correct. You can do so either by phone or email.
http://support.wdc.com/contact/index.asp?lang=en
Support by Country
http://support.wdc.com/country/index.asp
