Hi all, first post here and looking for some help.
I run a home server and replaced my 1TB elements for a 2 TB elements for back up use, so wanted to make use of the 1TB drive so removed it from the case and installed this into my server and was fine.
Now I was running out of space and have now updated the internal drive to a new WD Red 2TB which is up and running just fine.
So I thought drop the 1TB drive back in to the case and away we go. How wrong was I I have the drive re-fitted and it will not initialised. I can see the drive in Disc manger and the drive works fine if I plug it in through a SATA to USB lead and separate power supply.
What I have tried so far;
reformatted drive with SATA to USB and then re-tried
partition manger when in WD case same issue not initialised
The one think I thing I did when I had the drive in the server was to re-name the drive hence removed the WD and list of numbers from the drives name. So any ideas please or do I just buy a new SATA to USB case from e-bay and not worry about the WD case and board. As the drive is fine just will not work in the WD case and I think it is to do with the drive name that means the WD board doesn’t see it as a WD drive.
If anyone has a WD 1TB Elements drive I would like to know what the raw drive name is?
Thanks for the help.
