Finally getting to this. This is the copy of the info from Crystaldiskinfo on the I5 black1TB drives. #1 is the drive that is suspect, #2 is the the one out of my I3 machine that is currently being used as the back up drive. Since I don’t know how to read this, I’d appreciate your informed information on what it all means. Thanks!! Jim.
CrystalDiskInfo 6.0.4 Shizuku Edition (C) 2008-2013 hiyohiyo
Crystal Dew World : http://crystalmark.info/
OS : Windows 7 Professional SP1 [6.1 Build 7601] (x64)
Date : 2014/01/26 13:05:51
– Controller Map ----------------------------------------------------------
+ ATA Channel 2 (2) [ATA]
- TSSTcorp CDDVDW SH-224DB ATA Device
+ Intel(R) 8 Series/C220 Series SATA AHCI Controller - 8C02 [ATA]
+ ATA Channel 1 (1)
- WDC WD1002FAEX-00Z3A0 ATA Device
- ATA Channel 2 (2)
– Disk List ---------------------------------------------------------------
(1) WDC WD1002FAEX-00Z3A0 : 1000.2 GB [0/0/0, pd1] - wd
(2) WDC WD1002FAEX-00Y9A0 : 1000.2 GB [1/X/X, sp1] (V=04FC, P=0C25) - wd
Model : WDC WD1002FAEX-00Z3A0
Firmware : 05.01D05
Serial Number : WD-[Deleted]
Disk Size : 1000.2 GB (8.4/137.4/1000.2/1000.2)
Buffer Size : Unknown
Queue Depth : 32
# of Sectors : 1953525168
Rotation Rate : Unknown
Interface : Serial ATA
Major Version : ATA8-ACS
Minor Version : ----
Transfer Mode : SATA/600 | SATA/600
Power On Hours : 148 hours
Power On Count : 81 count
Temparature : 34 C (93 F)
Health Status : Caution
Features : S.M.A.R.T., 48bit LBA, NCQ
APM Level : ----
AAM Level : ----
– S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 192 135 _51 0000000029AF Read Error Rate
03 180 174 _21 000000000F8F Spin-Up Time
04 100 100 __0 000000000083 Start/Stop Count
05 200 200 140 000000000000 Reallocated Sectors Count
07 100 253 __0 000000000000 Seek Error Rate
09 100 100 __0 000000000094 Power-On Hours
0A 100 100 __0 000000000000 Spin Retry Count
0B 100 253 __0 000000000000 Recalibration Retries
0C 100 100 __0 000000000051 Power Cycle Count
C0 200 200 __0 000000000027 Power-off Retract Count
C1 200 200 __0 00000000005B Load/Unload Cycle Count
C2 113 104 __0 000000000022 Temperature
C4 200 200 __0 000000000000 Reallocation Event Count
C5 200 200 __0 000000000074 Current Pending Sector Count
C6 100 253 __0 000000000000 Uncorrectable Sector Count
C7 200 200 __0 000000000000 UltraDMA CRC Error Count
C8 100 253 __0 000000000000 Write Error Rate
– IDENTIFY_DEVICE ---------------------------------------------------------
0 1 2 3 4 5 6 7 8 9
000: 427A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 2020 2020 2057 442D 5743 4154 5243 3535 3230 3532
020: 0000 0000 0032 3035 2E30 3144 3035 5744 4320 5744
030: 3130 3032 4641 4558 2D30 305A 3341 3020 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 0000 2F00
050: 4001 0000 0000 0007 3FFF 0010 003F FC10 00FB 0110
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0000
070: 0000 0000 0000 0000 0000 001F 170E 0006 0044 0040
080: 01FE 0000 746B 7D61 4123 7469 BC41 4123 207F 0059
090: 0059 0000 FFFE 0000 0000 0000 0000 0000 0000 0000
100: 6DB0 7470 0000 0000 0000 0000 0000 0000 5001 4EE2
110: B392 FF52 0000 0000 0000 0000 0000 0000 0000 4018
120: 4018 0000 0000 0000 0000 0000 0000 0000 0029 0000
130: 0000 0000 0000 16E2 0000 0000 0000 0000 0000 0000
140: 0000 0000 0004 0000 0000 0000 0000 0000 0000 0000
150: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 3037 0000 0000 0000
210: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
220: 0000 0000 103E 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0001 1000 0000 0000 0000 0000
240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 ABA5
– SMART_READ_DATA ---------------------------------------------------------
+0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 10 00 01 2F 00 C0 87 AF 29 00 00 00 00 00 03 27
010: 00 B4 AE 8F 0F 00 00 00 00 00 04 32 00 64 64 83
020: 00 00 00 00 00 00 05 33 00 C8 C8 00 00 00 00 00
030: 00 00 07 2E 00 64 FD 00 00 00 00 00 00 00 09 32
040: 00 64 64 94 00 00 00 00 00 00 0A 32 00 64 64 00
050: 00 00 00 00 00 00 0B 32 00 64 FD 00 00 00 00 00
060: 00 00 0C 32 00 64 64 51 00 00 00 00 00 00 C0 32
070: 00 C8 C8 27 00 00 00 00 00 00 C1 32 00 C8 C8 5B
080: 00 00 00 00 00 00 C2 22 00 71 68 22 00 00 00 00
090: 00 00 C4 32 00 C8 C8 00 00 00 00 00 00 00 C5 32
0A0: 00 C8 C8 74 00 00 00 00 00 00 C6 30 00 64 FD 00
0B0: 00 00 00 00 00 00 C7 32 00 C8 C8 00 00 00 00 00
0C0: 00 00 C8 08 00 64 FD 00 00 00 00 00 00 00 00 00
0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 80 00 34 44 01 7B
170: 03 00 01 00 02 CA 05 00 00 00 00 00 00 00 00 00
180: 00 00 01 04 00 00 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C2
– SMART_READ_THRESHOLD ----------------------------------------------------
000: 10 00 01 33 C8 C8 C8 C0 00 00 00 00 00 00 03 15
010: 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00
020: 00 00 00 00 00 00 05 8C 00 00 00 00 00 00 00 00
030: 00 00 07 00 64 64 64 64 00 00 00 00 00 00 09 00
040: 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00
050: 00 00 00 00 00 00 0B 00 00 00 00 00 00 00 00 00
060: 00 00 0C 00 00 00 00 00 00 00 00 00 00 00 C0 00
070: 00 00 00 00 00 00 00 00 00 00 C1 00 00 00 00 00
080: 00 00 00 00 00 00 C2 00 00 00 00 00 00 00 00 00
090: 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 C5 00
0A0: 00 00 00 00 00 00 00 00 00 00 C6 00 00 00 00 00
0B0: 00 00 00 00 00 00 C7 00 00 00 00 00 00 00 00 00
0C0: 00 00 C8 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 15
Enclosure : WDC WD10 02FAEX-00Y9A0 USB Device (V=04FC, P=0C25, sp1) - wd
Model : WDC WD1002FAEX-00Y9A0
Firmware : 05.01D05
Queue Depth : 32
Interface : USB (Serial ATA)
Transfer Mode : SATA/150 | SATA/600
Power On Hours : 2800 hours
Power On Count : 1599 count
Temparature : 39 C (102 F)
Health Status : Good
APM Level : ----
AAM Level : ----
01 200 200 _51 000000000048 Read Error Rate
03 175 173 _21 000000001081 Spin-Up Time
04 _99 _99 __0 00000000065D Start/Stop Count
07 200 200 __0 000000000000 Seek Error Rate
09 _97 _97 __0 000000000AF0 Power-On Hours
0B 100 100 __0 000000000000 Recalibration Retries
0C _99 _99 __0 00000000063F Power Cycle Count
C0 200 200 __0 00000000002A Power-off Retract Count
C1 200 200 __0 000000000634 Load/Unload Cycle Count
C2 108 107 __0 000000000027 Temperature
C5 200 200 __0 000000000000 Current Pending Sector Count
C6 200 200 __0 000000000000 Uncorrectable Sector Count
C8 200 200 __0 000000000003 Write Error Rate
0 1 2 3 4 5 6 7 8 9
010: 2020 2020 2057 442D 574D 4157 3331 3636 3437 3433
030: 3130 3032 4641 4558 2D30 3059 3941 3020 2020 2020
070: 0000 0000 0000 0000 0000 001F 170E 0002 0044 0040
080: 01FE 0000 746B 7561 4123 7469 B441 4123 407F 0058
090: 0058 0000 FFFE 0000 0000 0000 0000 0000 0000 0000
110: 0722 279F 0000 0000 0000 0000 0000 0000 0000 4018
120: 4018 0000 0000 0000 0000 0000 0000 0000 0021 0000
130: 0000 0000 0000 16FE 00E6 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 3035 0000 0000 0000
220: 0000 0000 101E 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 84A5
000: 10 00 01 2F 00 C8 C8 48 00 00 00 00 00 00 03 27
010: 00 AF AD 81 10 00 00 00 00 00 04 32 00 63 63 5D
020: 06 00 00 00 00 00 05 33 00 C8 C8 00 00 00 00 00
030: 00 00 07 2E 00 C8 C8 00 00 00 00 00 00 00 09 32
040: 00 61 61 F0 0A 00 00 00 00 00 0A 32 00 64 64 00
050: 00 00 00 00 00 00 0B 32 00 64 64 00 00 00 00 00
060: 00 00 0C 32 00 63 63 3F 06 00 00 00 00 00 C0 32
070: 00 C8 C8 2A 00 00 00 00 00 00 C1 32 00 C8 C8 34
080: 06 00 00 00 00 00 C2 22 00 6C 6B 27 00 00 00 00
0A0: 00 C8 C8 00 00 00 00 00 00 00 C6 30 00 C8 C8 00
0C0: 00 00 C8 08 00 C8 C8 03 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 84 00 F8 43 01 7B
170: 03 00 01 00 02 B3 05 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D4
000: 10 00 01 33 C8 C8 C8 C8 00 00 00 00 00 00 03 15
030: 00 00 07 00 C8 C8 C8 C8 00 00 00 00 00 00 09 00
0C0: 00 00 C8 00 C8 C8 C8 C8 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5D
