As part of a Software package I purchased online from Ebay, I received a 80gb Caviar SE internal drive Model WD800JD. Was about to hook it up and noticed there was no power pins to plug power cable into, and the data cable that I am used to plugging in will not work.(STD IDE data cable). I guess it takes a Western Digital’s Serial ATA cable with SecureConnect, but how does one know which one ? Where does drive get power, thru this cable ?
And will this install in an older DELL Optiplex GX270 Desktop ?
This is the drive: http://wdc.custhelp.com/ci/fattach/get/8525/0/filename/2879-001081-003.pdf
Thanks for your help
