WD DL4100 - Miscellanous Messages
Hi
Everytime I start my laptop I keep getting a series of message about DL4100. For example the DL4100 is shutting down when it isn’t, either one of both of the links are not connected or have an intermittent connection - which it doesn’t have. A media scan is starting and 10 seconds later it tells me it has stopped the media scan. There are updates to various Apps but there doesn’t appear to be.
Once it has displayed all of these messages plus one or two more it is then fine until the next time I connect my laptop to the DL4100.
These problems seem to have started after the last update to WD software which was a while ago but its really beginning to bug me.
Kind regards
Steve
Have you cleared all the alerts from the DL Dashboard?
