WD Live Info Editor 0.62 Released
 WD Live Info Editor is a small program that can patch and edit your xml files for the WD TV Live 3G and WD TV Hub.
Get i here: http://sourceforge.net/projects/wdliveinfo/
Features:
  • Can patch xml files for WD live player (add zero to titles so wd player sorts them correct)
  • Can patch xml file back to orignal state
  • Can edit xml info files
  • Can get info from MP3 id tags
  • Can get movie info from Movie database
  • Can make new xml info files
  • Easy to use
Requirements:
 Windows xp or newer
I hope you will find it useful :)
I’ll give it a try… Thanks
