My WD Live updated today to the newest version , and now the screen keeps blinking back and forth from black screen to WD menu , cant acess it the blinking screen is every second
i tried resetting on the WD box , did nothing
Try with a full factory reset. Press and hold the reset button for 20 seconds.
i did the reset
since hardware is and software are different from the LIVE PLUS and the LIVE HUB you may want to try posting here: WD TV Live Firmware & Networking
Might find better support from people that use your device.
no ones got a answer thier either oh well guess ill try a diff brand thanks anyways
