Hi Everyone,
I have had a WD My Book 2TB/USB2 version for just over a year and started having some very strange problems in the last month. The permissions keep changing to I can only Read and not write files to it. Running Disk Utility the drive cant be unmounted usually, dragging the icon from the desktop to the trash and then running disk utility seems to work always find a problem with:
Checking volume bitmap.Volume Bit Map needs minor repairRepairs the file succesfully, then verify it again appears to be OK and then same problem with volume bitmap next time you run disk utility…
Seems to be slowing down the finder, looking in the drive at the files on there seems to take a very long time for the contents to appear and copying files out to back up for reformatting (when the permissions are correct) always throws up 'data could not be read or written (error code -36)Opening a small indesign file from the drive locks up indesign for 20 minutes before opening… As I cant backup the data from it to another drive without getting a finder error. Should I risk doing a firmware update to see if it helps?
I’m running Leopard (10.5.8) on mac book pro, usb cable straight into the macbook pro, My Book is mac os extended format. Still with 82 Gb available…
Any help or guidance would be very much appreciated Thanks!
