WD my Cloud 4TB Harddisk keep running
I have just bought a WD My Cloud 4 TB. It is updated with the latest firmware 2.11.140. I am running Windows 10 on my PC. On the drive i have aprox 19 GB music and some photo’s, but I haven’t realy loaded the drive yet.
However. the HD keeps running all the time.
I have been reading on this community about the issue, and found some suggestions including SSH commands:
/etc/init.d/wdmcserverd stop
/etc/init.d/wdphotobmergerd stop
and
update-rc.d wdphotobmergerd disable
update-rc.d wdmcserverd disable
I succeded in a stop of the wdmcserverd
But it couldn’t recognize the command /etc/init.d/wdphotobmergerd stop
also I wasn’t able to disable permanently
does anybody have any solutions to the spinning HD?
Are there new update for SSH commands to improve the issue?
There is NO official solution to the sleep issue on the single bay My Cloud’s. There are NUMEROUS threads on the sleep issue with various suggestions that while they work for one person may not work for the next. There are several causes for why the single bay My Cloud’s will not sleep for more than 10 or 15 minutes. Do a forum search for “sleep” to find the many threads. Here are but a few with some suggestions:
Note: Some of these possible workarounds may only apply to the first generation single bay My Clouds (v4.x firmware) and not the newer second generation single bay My Clouds (v2.x firmware).
http://wdstagingsplit.staged-by-discourse.com/t/wd-my-cloud-randomly-wakes-up-the-drive-when-drive-sleep-is-enabled/152748
http://wdstagingsplit.staged-by-discourse.com/t/mycloud-does-not-go-to-sleep-standby-perhaps-the-solution/158591
http://wdstagingsplit.staged-by-discourse.com/t/this-resolved-my-cloud-sleep-mode-issue/157059
http://wdstagingsplit.staged-by-discourse.com/t/new-sleep-awk/153431
http://wdstagingsplit.staged-by-discourse.com/t/sleep-time/95608
That will not hurt it, see more information here, http://www.wdc.com/wdproducts/library/SpecSheet/ENG/2879-800002.pdf.
cat0w
USA
