I am having a problem with my WD My Passport drive (Windows 10). I used it after some weeks and successfully installed a software that was on it. Then browsed through some folders on it. It disconnected and connected itself and asked to run a scan for errors and I did it.
Since then it is not showing up on.
I had set password on it, so, WD Unlocker quickly shows up to unlock the drive(I have auto sign in for my PC), but nothing happens.
Drive can be found in device manager and disk management but it is not initialized and giving Cycle redundancy check error.
When i Connect device it starts blinking then stops for a while then continuously blinks.
Can any one one help me if this is a lost cause or i can do anything.
I ahve been reading WD support community threads alot but to no avail.
Even drive is not allowing me to format when I tried to do so through WD Drive utilities.
