I have been using my WD Passport for roughly 1-2months just storing videos, musics, and pictures. So far it has been working great for the past couple of months, but recently when I plugged it into my laptop (same laptop as always), it will not start up. It shows that the device is being recognized under device manager, but unable to access the data under any of the drives. Also, under device manager, it is listed as a USB Mass Storage and not under disk with WD Passport like when it is working. I have 4 3.0Usb ports and have been trying them all, sometimes it works perfectly in one, safely removing it, plugging it back into the same one and it will not work again.
The data is still on the hard drive since the fleeting moments that I do get it to recognize, I can still see the folders/files are still there and the videos are still present and watchable. It just started recently when I was transferring data into my hard drive and it just completely disappeared on my laptop during the transferring of the data. I tried to look for it, but waited a couple of minutes until when I thought the transfer was over. I have tried uninstalling/installing it back in and it works, once, and then went back to doing what it did before with the error. Any tips and advice would be greatly appreciated thanks.
Side Note: i do not have any other computer to test this on in the house atm, but it use to work on my laptop for the past 1-2 months flawlessly and I have not done anything different to change any settings on it.
