WD RED 10TB PRO = 2 year warranty?
I would like to purchase several RED 10TB PRO but in Romania every retailer offers only 24 months warranty.
So does that mean that the 5 year warranty of these Pro drives doesn’t apply ?
Or can i contact WD if one of my drives fails after 2 years ?
Hello remi1,
Well, the warranty period of the RED PRO drive in Romania will be of 3 years according to our database. you may check the given link in order to know about the warranty period.
https://www.wdc.com/en-ie/products/internal-storage/wd-red.html
Warranty policy
https://support.wdc.com/warranty/warrantypolicy.aspx
If you have any issue then you should try contacting WD’s Technical Support about this.
http://support.wdc.com/support/case.aspx?lang=en
Hi Rocky, actualy the RED Pro drives have 5 year warranty :
https://www.wdc.com/en-ie/products/business-internal-storage/wd-red-pro.html
You linked to the RED drives, that only have 3 year warranty.
I understand that the implied warranty by retailer is 24 months but does that mean that if one of my RED PRO drives fail after 2 years, then i can contact WD for the warranty ? If so then i will buy a lot of them, cause i know you offer the best quality drives.
