Hi, I’m new to this forum so please excuse any mistakes I make.
I have a 500GB hdd in my computer at present which is becoming full.
I have purchased a 3TB hdd to replace it.
I am running Windows 7, 32 bit
I appreciate that windows 7 can normally only handle 2TB hdd.
I have used WD Acronis to clone the original HDD onto the new one both with the drive mounted internally and later with it mounted in a caddy.
The software appears to work correctly and produced in both cases a cloned drive.
However when I substitute the new hdd for the existing one it will not load Windows.
It starts to load and gets part way through loading the Wndows 7,4 colour logo but then stops and the computer restarts.
The screen says startup fault which it will cure but then gets into a continuous loop.
I would be grateful for any assistance.
Regards
Paul
