WD TV Hub goes into endless 'go' loop - stuck on 1st (sample) media file
This morning when I turned on my WD Live TV Hub it immediately started playing the ‘nature’ sample file. It just keeps doing this, while the file info, that’s usually displayed when you start a file, keeps flashing at the bottom of the screen. I can’t get out of this loop to try to do any troubleshooting. If I hit any menu buttons, it just keeps going back to this media file. It’s like someone is sitting on the remote (which is not the case :slight_smile: ).
I updated to the latest firmware on Wed 18 Sep. I can’t check the version, because I can’t get to it.
I have turned it off and back on, have removed my network cable, have unplugged the power. It keeps doing it every time I turn it back on. I can’t get to the menu to restore factory settings.
I still used it about 12 hours ago - no problem then.
Resolved the issue. Cleaned my wireless keyboard. Guess something got stuck in it. Sorry for hasty (and stupid) post.
Glad to know you were able to sort this.
Please mark the problem as solved, this might help other people.
