WD TV Live Hub Without Internalt Disc
Hi All.
Anyone know if you will be able to remove the disc from Live Hub, and use it, only by external USB Disc?
I think i have an faulty internal disc, and dont want to put in a new one.
Regards:
Monberg
I believe that you can operate it without the drive. It may give an error message about a missing / faulty drive. If you are out of warranty then its reasonably easy to get the drive out and see what happens. I replaced mine with a cheaper lower storage drive.
