WD TV Live Plus Firmware
Hoping someone can clear up a firmware question.
I am attempting to find and install 1.02.21 firmware on a WDTV Live Plus (WDBABX0000NBK) with the hope of using moviesheets. I have firmware 1.05.04_B-WDLXTV-Plus-0.5.1.1 but don’t think this is the same thing??? Can someone clarify the difference in the firmware for me if there is one?
Installing a previous firmware is not supported on this product. I found this on a WD Knowledgebase article:
  • Due to the upcoming final release, we will not be able to support rolling back firmware to any other version than the previous version (1.06.15_V or 1.06.16_B)
  • Downgrading your firmware is not recommended by WD. Please only downgrade if you experienced an issue that prevents you from otherwise upgrading or using your WD TV product
How to roll back the firmware on a WD TV Live HD Media Player or WD TV Live Plus HD Media Player
Moviesheets? Not with any (original) WD TV Live Firmware.
