WD TV Live Streaming will not play 'some' DVD iso menus
My WD TV Live Streaming media player has the latest firmware installed (1.11.14). Power cycling does not help. It happens every time and factory defaults does not help.
 I have two sets of DVD.iso files copied from DVD disks recorded from digital TV broadcasts. One set of isos from a panasonic digital recorder, one set from a pioneer digital recorder. Both sets of isos will play on a standard DVD player. Both sets will play on my PC when the isos are mounted and played with VLC media player.
Only the panasonic set will play with my WD TV Live with menues. The pioneer set will go straight to the first content with no menue selection available.
I have tried copying the original disks with a variety of disk to iso copiers ImgBurn etc but this makes no difference.
My WD TV player seems to not like one group of iso menues.
Please help, I need the menues.
Hi, check if you have the latest firmware installed, the problem could also be with the program you are using to make the .iso files.
