I have a WD1600BEVT 160GB 2.5" HDD, but it shows only 34GB and 31.5GB in WD Data Lifeguard Diagnostics and Windows control Panel.
The HDD was originally installed in a Netbook I bought previously, the problem was existing but I solved it by using WD disk management solfware (run in dos environment), its worked and was able to use all 160G in Windows XP.
But problem come again as the Netbook was broken, I removed the HDD from the Netbook and connected to my desktop using Windows 7 (my desktop is supporting to large HDD).
Can anybody tell me how to solve the problem? Thanks in advance : )
