WD30EZRX - 3TB Hard Drive
I have a WD30EZRX - 3TB hard drive that went to raw state and only showing 2TB.
The motherboard bios shows the hard drive as only 2TB.
Under Disk Management the Hard drive shows as 2TB and is formatted as GPT.
I think the video card on my motherboard failed and shut the PC down and caused my 3TB drive format to go raw.
I have recovered some of the information from the hard drive but it only shows as 2TB now instead of 3TB.
I have run the extended scan and everything has come back as passed and no issues found.
I dont know what the problem is and cannot work it out.
Maybe the hard drive has some firmware issue and needs resetting.
Any help would be greatly appreciated.
Hi fleasidewinder,
The link below will allow you to call support.
