Western Digital Drive Manager & Snow Leopard
Western Digital Drive Manager was last released in December 2008 (really prior to this date). With the release of Snow Leopard, Drive Manager throws an error at least every 5 seconds (into the logs). Removing Drive Manager allows using the drive without filling the log with errors, but disables capabilities inherent to the design of the drive (e.g. unmount the drive via pressing the button on the drive, etc).
When does Western Digital plan to release an update to Drive Manager for compatibility with Snow Leopard?
Are you using the latest version of the Drive Manager?  I believe it’s 2.25
i have a MY BOOK MIRROR 2 Tera, and i have a problem with it in snow leopard, It disapear in FINDER and my MAC says:
Disc incorrectly dismounted, it appears later.  ???
Yes. V2.25 is the 12/08 version which is not compatible with Snow Leopard.
Is there any news on a Snow Leopard compatible Version of WD Drive Manager in the near future?
Hey freedom,
I have the exact same problem that you are having. Every few seconds, the WD Drive Manager logs the following message to the console:
1/30/10 11:11:30 AM    WDDriveManagerStatusMenu[3670]    *** attempt to pop an unknown autorelease pool (0x841200)
Same here, but seeing as the software is more than a year old that’s no real surprise. Shame on WD, especially because they are selling the Studio Edition II as a “Designed for Mac”-drive and don’t even bother to have the software to support Apple’s latest OS.
I have exactly the same problem. No luck with WD Drive Manager 2.25 under Snow Leopard (OS X 10.6.2)
If someone working for WD is reading this: Can you give us any information on when there will be a fully Snow Leopard compatible version of WD Drive Manager?
I have exactly the same problem.  I’ve just updated to the latest firmware and WD Drive Manager and see these messages at least every ten seconds.  This occurs whether connected by USB or firewire.  I’m running fully up to date 10.6.2 on new iMac i7.
If I were to uninstall WD Drive Manager what features do I lose? (I can live without unmounting by pressing the button at the back of the drive…)
I’ll join the growing group - wonder how may others there are who haven’t looked in the console & noticed the problem? I’m going to email WD - not that I expect to see the problem solved soon.
Here is what I found out from WDC
Thank you for contacting Western Digital Customer Service and Support.
I apologize for this inconvenience. The WD Drive Manager is not compatible with Mac OS X 10.6. Please uninstall this software from your computer. Again, I apologize for this inconvenience.
I hope that we have met your expectations today and that you are satisfied with our service. If you have any further questions, please reply to this email and we will be happy to assist you further.
I’ll see if I get a response to the question “Do they plan to update the software?”
So if you remove the WD 2.25 software does Finder recognise My Book then? Have you tried it yet?
Yes, I deinstalled mine and everything works work fine.  Not actually sure what the WDManager is for…
can you advise me how to reove the WD driver please. New to iMac!!
You need to run the installer again; but press the Remove button instead.  Download it again from the WD support site if you didn’t keep it.
Here is what I learned from WD when I asked how to uninstall and if they have any plans to update.
_You don’t need an uninstall software in order to remove WD Drive Manager from your computer. On Mac, all you have to do is open “Macintosh HD” from the desktop, open the Applications folder and drag & drop WD Drive Manager to the Trash Can.
We are currently working on further updates for the WD Drive Manager. However, we still don’t have an estimated date for its compatibility with Snow Leopard._
Hope this helps!
Removing the Drive Manager is necessary until there’s a compatible version for Snow Leopard, which we are working on.  However, the drive should work fine without Drive Manager.
Are there any news on the driver update?
To be honest, I find this quite annoying. I bought a Studio II just two months before Snow Leopard was released, but now I am waiting for more than six months for a driver update. I mean, this is not a legacy product we’re talking about and Snow Leopards developer seeds were available months before the official release. Sorry, but this pretty much looks like you love to sell Mac branded products, but not to care for it. If I had known that the driver support for the Mac is that low priority on your schedule, I guess I wouldn’t have chosen a WD product (and I surely will think over this twice the next time).
You suggest to remove the Driver Manager, but this would spoil the availability of seeing the drive status and a Raid system is meant to increase data safety. So what is worth this when not noticing a failing device.
After all this is a huge disappointment…
Strange:  WD Drive Manager  works for me flawlessly on Snow Leopard.
