I was gifted a used WD 500gb Scorpio Blue drive from a MacPro; evidently, the drive was invisible to the CPU. Nevertheless, I was able to reformat it for PC use. It’s a naked internal drive, and I would like to put it into a case and use it as an external drive. Since it’s not SATA, I haven’t been able to find an adequate case. It uses the computer power through the USB cable. Any ideas are always appreciated and welcome!!!
–Dennis Woo, operations, KTEP-El Paso
–Deirdre Westenhauser, executive producer
