Which external drive
Hi; I need an external drive for my MacBook Pro mid 2012 retina; but I need a drive with an external alimentation, non by usb; which one can I choose? Thanks
p.s. my Mac can support a 3T Drive? And the drive, es. My passport, supports which Apple operative system? Mine is Mavericks
Hello WDdates,
I would suggest to use My Passport for Mac which comes in MacOS supported file format so there is no need to reformat in macOS supported file format in order to use in MacBook Pro.
Thanks; but I’d need of an external drive with a its own alimentation; not through usb…
Which wd external drive has an its own alimentation? I wouldn’t do it through usb! Thanks
As you are a Mac user I will insist you to go for WD my Book. It is one of the best external hard drive for Mac and it is also compatible with time maxh backup. The drive also offers 256 but AES hardware encryption.
Hi; do you know if my macbook pro retina mid 2012 supports a 3tera external drive?? Thanks
Hi; please, could you reply? Thanks
Is there a limit to the storage supported by my Mac?
Hi; could you tell me if my Mac supports a 3Tera external drive Western Digital or more Tera?
macbook pro retina mid 2012 15"
