Why so slow
Is anybody else having speed issues with this new media player.  Mine is connected to my 3b MyCloud and everything was fine right up until i started adding xml files to my shared location.
I’ve added some of the themes uses have uploaded (the alaska dark is fantastic and wd should take note of the design for any future releases) and initially thought that it may have been these, but I rolled back to the default grid theme and the issue still stands, in almost every view.
I’ve tried clearing the library, deleting all the cached files in various stages throughout the day and the problem persists; if i remove the xml files it flies through no problem.
Just seeing if anyone else has had this issue and if they managed to resolve it
Ignore, problem solved.  Using thumbgen to generate thumbnails and these where very large
I’m glad you were able to find a solution, and I thank you for sharing it with the WD Community.
Regards,
