Wi fi
Hello I just bought a wd live box and i bought a wi fi dongle to use with it, but it wont work, and i had it on my pc and set it up with my password, put it in the box , nothing :(, any help would be greatly appricated :slight_smile: david
If the wireless settings menu doesn’t come up in the settings when you attach the adaptor to the WDTV then it isn’t a supported adaptor, and nothing can really be done to make it work… all you can do is use a supported adaptor.
Here is the list of WD approved adapters. Make sure you look at the version/revision letters carefully. You can get the correct usb adapter, but if it is the wrong  version, it may not work. (Even though the part numbers are the same, manufacturers have a habit of changing the chipset in the adapters when they change versions).
Approved Devices
