Well, if you want guesses and intuition, as opposed to facts, I suppose I can answer… :smileyvery-happy:
I don’t think any WD devices actually “supported” a USB hub… but I seem to recall that some hubs would work with some of the earliest devices.
But a USB port only has to supply 500mA of 5V power… each Passport drive requires up to 1000mA of USB power. Even attached to a PC or laptop, people often find their USB port simply can’t drive their external hard drive, and their drive gets corrupted from the underpowering.
You can see the problem if folks start attaching multiple drives to an unpowered USB hub… people end up either ruining their hard drives, or burning out the USB port on the WDTV (or both).
Since you can’t put brains where there aren’t any, I think WD felt compelled to protect its users by actively blocking more than one volume on any one port… then people can’t fry their HD and can’t fry their WDTV. People still try anyways.
And it seems to mostly be the folks with powered hubs and/or powered drives that are saying “but I’m not gonna fry my stuff! can we pleeeez have it??”
So, WD could hope for the best and add hub support, and still end up with folks killing their equipment, or could play it safe. So far, it’s looked like they only want to play it safe.
B-Rad doesn’t have as much on the line… if his WDLXTV firmware supports some hubs, and you try to overdrive the port, he can just shrug and tell you you should have known better.
The other issue is that there isn’t any particular standard for hubs, so even if WD were to allow enumeration of more than one volume, it will mostly be the same boat as the USB wi-fi adaptors… “why can’t you support mine?? why can I only pick from these few hard-to-find ones?? etc…” WD won’t be able to support every USB hub. That simply will never happen.
As far as I know, it’s only additional drives that are currently blocked… users have reported success with some powered hubs, if they connect one hard drive, one wi-fi dongle and one USB keyboard… so, in a way USB hubs are “supported”… just not for additional drives.
As to why WD is only apparently contemplating adding multiple drive enumeration for the Live Hub, but not for the Live or the Live Plus, we can only guess that it’s as a marketing gimmick… they don’t want people shying away from buying their flagship, the Live Hub, and are less concerned with current owners who’ve already given their money to WD. That, in itself, is a whole other rant.
But, the last I’d seen, over in “Ideas”, is that it’s planned for the future for the Live Hub (whether it will make the light of day is a whole other question), but it’s unplanned for the Live and Live Plus. So, I wouldn’t hold my breath on ever seeing multi-volume enumeration on a Live.
