Will WD TV Live WDBHG70000NBK (NTSC) work in Asia?
I got a WD TV WDBHG70000NBK NTSC in US. I’m planning to take it to India.
Will it work on PAL TV there?
I feel, it should not be a problem, since I would be either using the Composite AV or HDMI output mode.
Kindly advise.
Cheers!
Wrong forum.
The forum you need is here:
http://community.wdc.com/t5/WD-TV-Live-Streaming-Media/ct-p/wdtvlive_streaming
But to answer your question:  If you’re using HDMI, PAL vs NTSC has no meaning.
If you’re using Composite / Component, then you can follow the instructions in the manual to change the mode from NTSC to PAL and vice versa.
