Ok. So I got my unit today.
Don’t have my wifi adapter, so I haven’t actually tested playing anything, but here’s what I see in my limited testing.
I set the Live Plus to 1080i component 60Hz, YUV color. If I power it off and then back on, the screen is messed up while the box is booting up, but just before the menu comes up, the screen blanks for a couple of seconds and then it the menu comes up normally.
If I plug in HDMI and set it to 1080i 60Hz, I get the exact same results.
In either case, when I go into the menu to look at the setting, it’s unchanged from what it was before power off.
For the guy above that says it’s not remembering the setting, are you sure you let it boot up all the way to the menu? At first, I was disappointed that when I turned it back on it wasn’t working. It took me a bunch of tries before I waited until the menu came up and figured out it was ok then. Sounds like you’ve been around here a while, so I’m sure you know that, but figured I’d put it out there.
Since my TV only has 1 HDMI port, I think I’ll just leave the Live Plus in via Component. Should be just as good video quality as the HDMI connection and I don’t have to fiddle with an HDMI switcher.
I powered off and on a few times, so I think I’m ok, but I’ll test it a little more in the morning.
So far, very happy.
Now, looking forward to playing some content.
Hopefully, no issue with video outputting through component to my TV and audio via optical to my receiver at the same time.
