Accessing My Cloud Mirror issue... HELP!
I cannot access my drive via Finder on my iMac or any of the software I use. I was able to see and access everything prior to El Capitan update.
I can connect direct to the router and then see everything on my drive.
I have tried both the 4 sec and 40 sec reset procedure but no difference.
Can anyone help as I need to have direct access urgently to my content.
Thanks in advance
Hi there,
Have you tried manually mapping the drive on the mac to see if this helps? Perhaps also setting a static ip also could help.
Unfortunately neither of these things I know enough about to do.
Are you able to desktop assist?
Mark
Hi there,
On this case i recommend contacting support for further assistance on this issue:
Try connecting using cifs or afp. smb on the latest El Captain has issues.
