I have been reading this forum over the past few days and I have not seen anyone mention premature platter wear or wear leveling with respect to disabling the head parking timer. I do see most people are electing to set a timer value of 300 seconds vice 8 seconds which I personally agree with. If you disable the timer then the heads sits on the platter all the time inducing wear, a fact you cannot get around.
So I have a wear level question:
If the heads never park, do they normally sit at one location when not in use or do they move around the platter to ensure wear leveling of the platter?
I ask this because it looks like WD made a change to the Red series where the drives use to have the timers disabled but now they are set to 8 seconds. I’m sure there was a reason for it, I’m just curious if I should change my WD Red 2TB drives from a disabled timer (factory value) to a 300 second value which makes great sense to me for my home system which only serves as a backup device and streams video a few times a week.
