I can set up sharing from the WD TV Live SMB (it’s unfortunate they use the same term for both, but I mean the kind that allows you to connect TO the WD from a computer). If I don’t set password protection, it works, and I can copy files to and from the attached USB drive from a remote computer (although sometimes the connection drops for no apparent reason).
What I can’t figure out is password protection. It’s not mentioned in the User’s Guide, but there it is after you enable sharing. Again, no documentation, but it apparently requires a capital, lowercase, and number, because without it the thing just stares back at you stupidly. So then you go to the computer, try to connect, but you have to enter a username as well as the password you set. What is the necessary username?
Thanks, Jim
