I’m pretty new to the WD Live Hub…
My question is; when i go to the change view withing videos… i change it to where you can see the info that i you can get of " get content info". All that works…
However it only shows when i get to the file itself. My hard disk is organised like this : you get folder like animation, action, etc… then if you go into that folder you get all the movies (which are again in a folder).
I only see the info and the nice layout when i get into the folder of the movie (at the fille itself). When i change the filter from folder to view all… then it works… but then i lost all my structure of the maps and movies. Is there a way when i’m at the folders of the movies i can see the info? Now everything is N/A. (i only see the thumbnails under at the screen.)
I would like to see the info and the same lay-out when i browse through the moviefolders, without having to change the filter to “view all” and lose the structure…
Many thanks in advance…
Greetings
Jonathan
